Enrique Scalabroni analyzes the suspension geometry from 2013 cars front suspension, both pull & push rod and talks about which is best in 2014.
Part 1
Part 2
I haven't looked through the rest of the video(s) but the first example there ~40 seconds in is indeed a "pull-rod" topology. Imagine the chassis sitting at a slightly lower ride height and it will be a bit more visually obvious.bianpie wrote:I might not be the right one to talk about it, but I tend to believe the first drawing of the pull-rod must be wrong. It looks to me a push-rod. Ferrari has the rod inclined the other way around. And with the new regulations, the rod should get even more inclined, so the axial tension load should get smaller (and not bigger) than in 2013.
I'm asking for your opinion, as I'm a beginner...
If I look at the inclination of the first pull-rod, I see an angle lower than 90 degrees with the vertical force. Based on my civil engineering background, this should compress the rod, and not pull on it. Both Ferrari and McLaren have a pull-rod making an angle of more than 90 with the vertical force.Jersey Tom wrote:I haven't looked through the rest of the video(s) but the first example there ~40 seconds in is indeed a "pull-rod" topology. Imagine the chassis sitting at a slightly lower ride height and it will be a bit more visually obvious.bianpie wrote:I might not be the right one to talk about it, but I tend to believe the first drawing of the pull-rod must be wrong. It looks to me a push-rod. Ferrari has the rod inclined the other way around. And with the new regulations, the rod should get even more inclined, so the axial tension load should get smaller (and not bigger) than in 2013.
With control arm inclination being extreme such things - and the resolution of forces - are at times a bit less intuitively obvious. Hence why I use "pull-rod" a bit loosely. For that matter I'd have to work it out but even how much vertical load the pull rod reacts in that case (of nearly flat to ground with very high control arm inclination). I'd think the only time a pull- or push-rod should be supporting 100% of the vertical load of the car is when the control arms are perfectly parallel to ground.
Add to that not needing to preserve the tyres as much as before. I think then rumors about macca going back to push rod are true after all. I see no reason why Ferrari should not revert back to push rod either.marcush. wrote:Quite intriguing how Scalabroni does not clearly state the pullrod as used by Ferrari and Mclaren does rely almost completely on scrub (track Change )to create any meaningful damper movement in bump but instead says the inclination of wishbones is purely for aero reasons.
indirectly he confirms as much as he outlines how the pullrod loads rocket as you reduce the wishbone downward angling..
I´d think the front pullrod as we have seen it in 2013 is dead now .
I agree with you, but I don't think the decision will have much to with the need to preserve tyres (or, then again, perhaps it does....)Shrieker wrote:Add to that not needing to preserve the tyres as much as before. I think then rumors about macca going back to push rod are true after all. I see no reason why Ferrari should not revert back to push rod either.
