SectorOne wrote:Drivers are gonna lose that little bit of nose on a regular basis in races i think.
It doesn´t help that it has a slit in it as well
I will say this though, 2014 liveries seems to be a "fabulous" looking year
The worrying things about that is that the teams probably wouldn't mind if the tip was removed, removing that blockage. You'd hope that anyone running like that would be black and white flagged in order to completely remove the possibility of doing it on purpose.
Close up grab of the rear from the 360 render:
