Have you seen it?
This certainly looks prettier and more proportionate that the monstrosity of a nose they revealed yesterday.Vanja #66 wrote:This?Mr.G wrote:What about the carbon nose at abou 0:40 look different but still matching 2014 regs.
http://i1364.photobucket.com/albums/r72 ... bdd71f.jpg
Looks to me like one of those speculation MCD pictures... Just need to find it... There it is.
http://livedoor.blogimg.jp/mame_nafr/im ... 747f39.png
I think the idea is a gigantic PITA to make work predictably. A driver does not want a rear suspension which has a dramatic threshold-like operation envelope. And the idea will most likely be shot down by FIA immediately. Also, flex of the rear wing is tightly controlled from as far back as 1999.daveyrace wrote:After being a long time reader of the threads I have decided to participate, with my limited knowledge. Hello all!
I had a thought and thought I would put it out there.
This is purely speculative, what if the rear wing endplates, which do not appear to be connected to the new upper rear wishbones are designed to push down onto the wishbones when the wing and suspension is loaded at speed or through cornering. Would this in effect direct the rear wing downforce onto the rear suspension? Which would be advantageous? It would pass scrutineering as there is no connection at rest. From the images so far, which heavily shy away from the rear of the car the gap between seems very tight. We have all seen previous rear wings 'wobble' (especially last years merc) you would expect a larger tolerance especially when the rear wing is only supported by the single central pillar which has a very slender cross section.
If I am right this years must have is a flexi-rear wing not a phallic front If not Mclaren have done a good job with their tolerances =D>
Feel free to shoot me down.
You wouldn't gain anything by directly pushing on the suspension. The downforce generated is still the same. The only difference is the downforce becomes unsprung weight.daveyrace wrote:After being a long time reader of the threads I have decided to participate, with my limited knowledge. Hello all!
Yeah, it's that useless it's been explicitly banned by the regs for decades....seriously, just re-read what you wrote and hang your head in shame.Del Boy wrote: You wouldn't gain anything by directly pushing on the suspension. The downforce generated is still the same. The only difference is the downforce becomes unsprung weight.
Wouldnt it make the rear wing a movable aero device ,which are not allowed apart from the rear wing flapdaveyrace wrote:After being a long time reader of the threads I have decided to participate, with my limited knowledge. Hello all!
Already said that looks like the MP4-22 noseVanja #66 wrote:This?Mr.G wrote:What about the carbon nose at abou 0:40 look different but still matching 2014 regs.
Exactly. The video cuts at the closeup of the shrouded car before the reveal, so the could re-use the footage for any launch. I'd guess they shot the lead-in for the reveal maybe even years before. It's a carefully staged and timed sequence - they're unlikely to have included anything not already in the public domain, no matter how trivial.henra wrote:Yup.stefan_ wrote:That nosecone looks more like this
http://www.f1fanatic.co.uk/wp-content/u ... 2007_3.jpg
or
http://wakpaper.com/large/Mclaren_wallpapers_100.jpg
Looks very much like it.
Maybe just an older sequence in the clip?
To me the pylons look to high for the 2014 regs.
This nose looks rather as if it was made for a 625mm AA line bulkhead.
