Notice that the new cars dont seem to be much different in sidepods so far?
However the openings are huger.
Can you explain why this should be the case?n smikle wrote:At lower rev range and lower car speeds especially, the 2014 power unit makes much much more horsepower than the outgoing V8.
Just had a quick play with this to see the implications of the above limitation.Blanchimont wrote:Can you explain why this should be the case?n smikle wrote:At lower rev range and lower car speeds especially, the 2014 power unit makes much much more horsepower than the outgoing V8.
Remember that the fuel flow is limited to:
"5.1.4
Fuel mass flow must not exceed 100kg/h.
5.1.5
Below 10500rpm the fuel mass flow must not exceed Q (kg/h) = 0.009 N(rpm)+ 5.5."
Code: Select all
RPM kg/h bhp ftlb
00 006 000 000
01 015 087 457
02 024 141 370
03 033 195 341
04 042 249 327
05 051 303 318
06 060 357 312
07 069 411 308
08 078 465 305
09 087 519 303
10 100 600 315
11 100 600 286
12 100 600 263
13 100 600 242
14 100 600 225
15 100 600 210
Your calculations seem to be correct, power depends on the maximum fuel flow allowed for 2014.mrluke wrote:I dont have any information on the power curve of the old V8 but I expect it to be very peaky and to make peak torque somewhere around 16-18krpm this gives about 230ftlbs of torque. I would suggest that in the 6-12krpm range its going to be making an awful lot less torque whereas the v6 is making about 300ftlbs.
Just for the sake of keeping with actual data. Here are some charts from the Cosworth V8 and V6. Taken from the Race Engine Technology #72 and #73. (That magazine is really worth reading).Blanchimont wrote:Your calculations seem to be correct, power depends on the maximum fuel flow allowed for 2014.mrluke wrote:I dont have any information on the power curve of the old V8 but I expect it to be very peaky and to make peak torque somewhere around 16-18krpm this gives about 230ftlbs of torque. I would suggest that in the 6-12krpm range its going to be making an awful lot less torque whereas the v6 is making about 300ftlbs.
But why do you compare the torque of the 2013 engine at 16-18k with the torque of the 2014 engine at 6-12k without multiplying with the gear ratio?
I guess this has something to do with the combustion efficiency and flow through the combustion chamber. But this is only a guess.Holm86 wrote:Don't get why the engine would produce maximum power at 11.500 rpm instead of 10.500. Are they deliberately waiting to use the max fuel rate till 1000 rpms later than allowed?? Is there any advantage in doing so? A more usable power curve? I would think the engine would be slightly less efficient.
I tried to achieve it, and it seems that the cars will be with KERS at full power be faster than until now. Because the max power is about the same as before (maybe a bit less) but the power delivery is much flatter. But on the other hand the cars are a lot heavier. So it seems possible that Lotus (or was it another Team) said that their car is as fast as their car last year.Blanchimont wrote:Thanks rscsr, your second picture is very useful here. If the power curve of the V6 engine would be stretched to the right by a factor of ~17000rpm/11500rpm to account for the different gear ratios, we would see that the power curves are very similar to each other.
