FSAE Design -- help needed please
dnomdec
dnomdec
I recently joined our school's FSAE team and I am designing the aero components of our first car.
I would love to hear any information about FSAE cars, especially the effects of aero devices on their handling characteristics (I am also reading those articles posted in the weight transfer thread).
In particular, if anyone has experience in the competition and can tell me some of the airfoils used, how they choose the CoP location or downforce bias, that would be great.
Any information is welcome though.
Thx a lot!
AeroGT3
AeroGT3
I just PM'd you with my response, but I'm going to post it here should anyone else be interested.
I'm definitely going to give you any answers or research or results, but I'll give you some ideas on how to start:
I would start with a DF target, and get that from a systems level perspective. Contrary to what you think, performance comes last. Integration and the rules come first, IMO. Before you even THINK about how much DF you want and from what component, think of how much the chassis can handle (was it build for Aero?) and how much you'll compromise other subsystems. On our car, the Aero represents a significant load that changes the safety factor a lot. Things like that need to be considered. Find out where you can physically put things before you design them. Again, rules and placement first, performance second.
Start out with where you can mount. If you can mount to unsprung, that makes the analysis on balance very easy to do for the chassis team. If not, well, simplify your models or forget that altogether and start with some simple goals. Our team aimed for 100 lbs @ 40 MPH, which has a big impact on a 319 lb car :)
You asked for how to pick a CoP and bias? That's a systems engineering task, and something the whole design team needs to design. The same goes for other questions like "how much power should we shoot for?" Sit down with the chassis folk and have a good talk. What do they want to see in terms of dynamics? What kinds of loads can the car handle? How will your target DF's, if met, affect the balance and the handling characteristics of the car?
If you are able, get a very simple lap sim going. Prove aero can work. Use very basic drag models and so forth. Just get an idea (order of magnitude) on what you can expect to accomplish.
Do you plan to run an undertray, front wing, rear wing? If so, target what you want from each, remembering that the tray is infinitely more efficient. Try to use wings as trim devices only.
Typically aero is not popular in FSAE because in order to get noticeable DF, teams think they need 45 degree angles of attack on a NACA 0012. They don't. They need undertrays, and I only know of one school outside my own that does an undertray. They are very, very tough, but if you think you can do it, do it.
Again, integration and the rules are first. Where can you mount? Using endplates, steel supports? Unsprung or sprung? What materials? What manufacturing processes are at your disposal? How many people do you have to build the things? What are the physical limitations on your design space (span, chord, etc.) Don't get thinking on a gnarly wing with twist and changing AoA if you don't have the gantry mill to make the female molds.
As far as wing design goes, start simple. How I started was by just picking a high lift A/F, like the Selig S1223 or something.
Start by doing your basic 2-d analysis. I wrote a panel code that did 5-D optimization on a two element rear wing with a linearly varying vortex distribution, with Thwaites method used to predict stall. In some cases I was within 5% of CFD, even on separated parts. Do some CFD on your airfoil and get the drag polars. If you're newer to CFD, use different viscous models and come up with several curves, and put correction factors based on zero AoA numbers you do by hand using Blasius or something like that. This was probably overkill, but I have a very disciplined and thought out approach on how the cross sections were selected. I personally wanted to justify every design decision and optimize numerically everywhere I could. That's just my approach though.
I do however strongly discourage the "build and test" methods as for an operation as small as an FSAE team, that's just not going to cover enough of your options and is very time consuming and expensive.
That gave me an ideal 2-D section. Then I went to 3-D. First, I characterized the environment by doing a wind tunnel test to survey the wake. That gave me effective Cp's and thus flow rates across the plane I wanted to place the wing in.
I wrote a code that optimized the chord. I set the span at the max the rules allowed, then wanted to look at two things - do I want a really big wing at a low Cl to give me low drag, but high weight, or a small wing that weighed less, but had high drag. Which would reduce acceleration the most?
I set a target DF and then set a multitude of different chord lengths, determine the angle of attack required by that particular size that would meet the DF target, and the resulting drag and weight. I used crude weight estimates at first (some lame 2nd order polynomial I guessed) and then refined them later after wings of multiple sizes were actually built and weighed. I applied the weights and drags to the car and picked the chord length that gave the lowest reduction in acceleration.
Things like that were the thought processes I followed. From there it went in depth into endplate configuration and other things we are still working on. Right now, we're working on aerodynamic twist, using 3-D panel codes in addition to CFD. What kinds of twist functions (linear, polynomial, sinusoidal?) give the best performance and so on. That's the more detailed stuff most teams never touch, but I have the time and manpower to do that stuff.
Hope this helps and isn't too complex, I can tone it down a bit if you have more basic questions.
flynfrog
welcome to the forum
but im not going to give out years of my teams research so you don't have to do it. sorry
Ill see you in detroit
AeroGT3
AeroGT3
flynfrog wrote:welcome to the forum
That post really didn't do anything useful, now did it? I don't think you need to respond with answers or give out your teams research, but some ideas on where to start couldn't hurt anyone. I doubt he's going to contend with your teams Aero if you do!
You yourself made a thread asking for help on how to design an underbody. What did you want us to give you "years of [our] teams research so you [wouldn't] have to do it?" :P
We all started out not knowing what the hell we were doing, so asking for some advice on how to start isn't such a big deal!
flynfrog
point taken
check out the usual recomened books
competition car aerodynamics by mcbeath for some starting points
i cant really do better explain than aero did
also look at other teams cars such as rolla or UTA we aer just getting some testing in once the snow melts and good luck
miqi23
miqi23
BTW flyfrog, just wondering if you have designed that underbody? Can you quote some down-force figures at 20 m/sec please...
flynfrog
miqi23 wrote:BTW flyfrog, just wondering if you have designed that underbody? Can you quote some down-force figures at 20 m/sec please...
i ended up going with a strait underbody the curves were so shallow that there was almost no difference between a strait or curved tray
I dont have the real world data yet (see snow) But i hope to get some real world numbers next month.
tomislavp4
miqi23, I have exel document from some team (not a clue which :oops: )
they got 75lbs at 40mph...
BreezyRacer
BreezyRacer
tomislavp4 wrote:miqi23, I have exel document from some team (not a clue which :oops: )
Those are pretty good numbers Tom. Do they really mean anything? Any photos of what they are for? I imagine that includes undertray, and wings?
tomislavp4
No, no pictures sorry. This is from the document:
-Aerodynamics (if applicable)
front wing (lift/drag coef., material, weight):N/A
rear wing (lift/drag coef.,material, weight):N/A
Undertray (downforce/speed):75lbs.at 40mph, center of pressure 2" aft of vehicle CG
That´s all... :roll: If i figure out where did I found it I´ll post a link :wink:
tomislavp4
miqi23
miqi23
Breezy, is that more than your design?
flynfrog
those numbers done mean anything a team can put what ever they want there
miqi23
miqi23
Didnt get you mate, what you mean?
AeroGT3
AeroGT3
tomislavp4 wrote:No, no pictures sorry. This is from the document:
I know a team that achieved similar numbers for a fact with their tray. It's possible. It's just hard to do.
