![Image](http://www.formula1.com/wi/enlarge/sutton/2013/dms1430a235.jpg)
![Image](http://www.formula1.com/wi/enlarge/sutton/2013/dms1430a237.jpg)
![Image](http://www.formula1.com/wi/enlarge/sutton/2013/dms1430a238.jpg)
![Image](http://i.imgur.com/oC7rPd5l.jpg)
Sauber had an extremely narrow sidepod last year that caught the eye of everybody. I doubt they would have changed it if they could've kept it. I think it must be some kind of PU requirement and that Ferrari took a gamble on it and risked more with theirs... The season will tell usmkable1370 wrote:Can anyone explain why the Sauber has so much larger sidepods than the Ferrari F14-T if they use the same power unit? Assuming they must be using the same radiators and intercooler set-up, so is the sidepod shape strictly down to the individual teams' aero ?
Going through I accidentally clicked the down vote on the post in the quote can a mod remove it or somebody else up vote it to put it back neutral.Disgrace wrote:Could someone explain what's behind Sauber running an asymmetrical rear wing? It appears as though they have run the symmetrical version with two dips in the wing, then two others with a single one on either end.
Just did it.trinidefender wrote:Going through I accidentally clicked the down vote on the post in the quote can a mod remove it or somebody else up vote it to put it back neutral.Disgrace wrote:Could someone explain what's behind Sauber running an asymmetrical rear wing? It appears as though they have run the symmetrical version with two dips in the wing, then two others with a single one on either end.
What do you mean by missing aero parts and that leading to Sutils crash ? You think a few sidepod vanes would stop him from crashing?Bikeman wrote:Sauber had only very little of their aerodynamic parts on the car (for example the missing sidepod vanes). They were mainly running system checks and not goining to the limits yet. The missing aerodynamic stuff might also be the reason, why Sutil crashed twice. I'm wondering, how much faster the car will be, once it is fully dressed and how much the overall apperance will change.
.. well, I assume they had not the downforce as others and I guess the general behavior of the car was not as it would be. Therefore it might be harder to keep it under control. Don't missunderstand me, I'm not searching for excusses for Sutil. Loosing the car twice is kind of..Huntresa wrote:.. What do you mean by missing aero parts and that leading to Sutils crash ? You think a few sidepod vanes would stop him from crashing?
They still do for safety reasons.Sebp wrote:Speculation warning:
I am of the opinion that the incidents more likely had their roots within the new braking system. The rear breaks don't have a hydraulic link to the brake pedal anymore. So there will have been a lot of fiddling around with the software during these test days. Ergo, call IT and not the aero department.
Okay, my bad.dren wrote:They still do for safety reasons.
From here:11.7 Rear brake control system :
The pressure in the rear braking circuit may be provided by a powered control system provided that :
a) The driver brake pedal is connected to a hydraulic master cylinder that generates a pressure source that can be applied to the rear braking circuit if the powered system is disabled.
b) The powered system is controlled by the control electronics described in Article 8.2.
