You are burning the same amount of fuel but you are covering a lot more ground. So you complete more of the lap for a given amount of fuel.hollus wrote:No, you use the same fuel in acceleration than in the rest of the following straight. Acceleration is where the burnt fuel gives you the most lap time, though.Lazy wrote:There are other factors as well, for example more df means higher exit speeds and therefore less fuel is needed for acceleration and acceleration is where most of the fuel is used...
Therefore the faster your exit speed the less time you spend accelerating and the less fuel you need to complete your race distance.
