Can you please post a link to the article? I can't find it on omnicorse.it.eslam1986 wrote:According to omnicorse.it Ferrari engine would be 12 kg overweight .
Thanks.
EDIT, found it: http://www.omnicorse.it/magazine/34530/ ... sovrappeso
Briefly, they're saying that all team are really struggling to get into the minimum weight (691kg), and that the teams are more or less 30kg over this limit.
All the overweight is depending on:
- Static tests for the monocoque, which are now more difficult to pass, cost about 5kg (based on a F1 designer's personal confidence).
- Hybrid systems are now weighing much more (25kg from last year ones, now about 60kg).
- The Power Units are heavier than 145kg. For example, the Ferrari's Power Unit, which is one of the lightest PU, is 12kg overwight (I don't know how and where they found this info...).
This is why some teams asked to increase the minimum weight from 691 to 700kg. Ferrari was contrary because they're confident that they'll pull off weight, working on wiring and electic systems.
In the end they say that one of the key area to find performance in 2014 will be the weight reduction.
