turbof1 wrote:
For me the most important thing to know is how its coëfficient compares to the rear wing.
Let's look at the fact that drag calculates as
Fd=Rho/2 *Cw *A*v^2
So let's have a look:
Rho: unchanged compared to Beam Wing
Cw: defnitely higher (Guestimate: >2 times higher).
A: >2 times as much.
v^2: Unchanged.
=> Drag probably >4 times higher than Beam Wing.
DF surely not higher than Beam wing.
=> L/D of the device itself probably around 4 times or more worse than Beam Wing.
The big unknown is the effect of this device on the diffuser compared to the Beam Wing's.
That said I would be surprised if it works much better on the diffuser than the Beam Wing.
The other Team's Designers would probably also be keen on having an idea how efficient it is.
I'm still not sure if we will see it on all tracks. Gutt Feeling says: Possibly no. Especially Monza and Spa. Then again the questions is if they accept a little disadvantage on those tracks rather than change it to 'normal' ones, endangering their case that it is simply their normal Suspension and not some aerodevice in disguise.
