Correct...Per wrote:The toe link is the UPPER of the two 'mushrooms'. It is clear in this picture posted earlier by Owen.C93: http://www.formule1.nl/media/uploads/me ... 593.49.jpg
Here you can clearly see the upper wishbone consisting of two normal members. Behind the upper wishbone is the toe link, which has the bell shape.
The lower wishbone has a normal front member and a bell shaped rear member.
http://www.f1technical.net/forum/viewto ... 43#p481943
