Holm86 wrote:dren wrote:turbof1 wrote:How much energy can you roughly realistically harvest with the mguk?
The limit is 2MJ/lap MGUK->ES but that is bottle necked by the 120kw limit in/out on the MGUK. With the amount of time the cars see braking and figuring the MGUK will absorb all 100% of brake energy (which it most certainly will not) it only nets around 1MJ/lap. It will be much less than that with brake bias.
I don't think you can look at it directly like that. Because it takes a hell of a lot more than 120 Kw to stop the car. So even with the brake bias there should still be 120 Kw for the MGU-K to harvest.
And 2MJ with 120 Kw harvest is done in 16.66 sec. I don't know how much time of a lap is pure braking but I think its due able.
I did some quick calcs on another forum, based on Brembo braking data provided to me by another member.
I assumed 60/40 brake bias split.
Code: Select all
Circuit Energy
SINGAPORE 2460
ABUDHABI 1846
AUSTIN 1567
BAHRAIN 1504
MONACO 1517
MALAYSIA 1463
KOREA 1349
HUNGARY 1284
SPA 1292
CHINA 1216
NURBURGRING 1171
CANADA 1159
CATALUNYA 1138
BRAZIL 1064
INDIA 1064
SUZUKA 1061
AUSTRALIA 992
MONZA 938
SILVERSTONE 730
And then it was pointed out that the bias would be further forward - perhaps 65/35, so I recalculated.
Code: Select all
Circuit Time Change
SINGAPORE 2455 5
ABUDHABI 1843 3
AUSTIN 1559 8
BAHRAIN 1504 0
MONACO 1507 10
MALAYSIA 1449 14
KOREA 1347 2
HUNGARY 1284 0
SPA 1288 4
CHINA 1216 0
NURBURGRING 1171 0
CANADA 1159 0
CATALUNYA 1138 0
BRAZIL 1064 0
INDIA 1064 0
SUZUKA 1056 5
AUSTRALIA 992 0
MONZA 937 1
SILVERSTONE 730 0
Even on this very basic analysis, you can see that the cars will struggle to recover 2MJ from braking, and some tracks won't even allow half of that.
