I think the MGU-H will be harvesting power before full boost. Assuming full boost coincides with the maximum fuel flow rate and 10,500rpm.Holm86 wrote:The MGU-H starts harvesting just at soon as the turbo reaches maximum boost.turbof1 wrote:Don't forget that the mguk will be delivering power to the mguh to spooling the turbo under braking, which will not go to the ES. Realistically the mguk needs to harvest more then 2MJ to get everything out of a normal lap. The mgu-h will barely contribute anything to the ES. Perhaps a very tiny bit just when braking starts. In a perfect world you want the mgu-h not take anything from the ES, either relying on exhaust gasses or the mguk to spool the turbo, and the mguk harvesting enough to get 2MJ plus enough energy to let the mguh spool the turbo (to negate turbo lag when getting back on the power).
There may be situations coming off corners where the MGU-H is harvesting power but the chassis can't take it (traction limited). So, if the car is below, say, 150km/h the MGU-H sends energy to the ES, but above that it sticks it straight onto the MGU-K. They may even choose to blend the transition over 20-30km/h, during which some is sent to the ES and some to the MGU-K.
