Red Bull RB10 Renault
Robbobnob
Robbobnob
33
Re: Red Bull RB10 Renault
Certainly a significant lack of 'whirring' and the high pitch sequeeling of the ERS that is evident on the other cars. Probably a good indication that the KERS (i dont care what its called now, its KERS) regen isnt anywhere near at full potential
beelsebob
beelsebob
85
The high pitched squealing is not caused by the ERS. It's the turbo. Which suggests that they're running the engines under low compression ratios o.O.
Owen.C93
Owen.C93
177
Compression ratio or did you mean boost pressure?
beelsebob
beelsebob
85
Owen.C93 wrote:Compression ratio or did you mean boost pressure?
Uhhh yes, I do of course mean boost pressure.
Helios
Good view of the S-Duct
Winter Testing 2014 - Session 2, Day 4 - Bahrain (22.02.2014)
hardingfv32
hardingfv32
35
What do you think the device is mounted low on the bulkhead on yellow tipped posts?
Brian
Pilatus
22
Brian
Steering rack, with some kind of connector/connector housing on it (probably for mandatory TV cameras).
theWPTformula
50
Alexgtt
Alexgtt
Maybe all this strategy talk is for the team thread?
So, back onto the RB10. Why no monkey seat on the RB? Surely with the exhaust blowing underneath they are essential this year?
aleks_ader
90
Alexgtt wrote:Maybe all this strategy talk is for the team thread?
Wait! They need sort out packaging first. That is last think to worry RB at the moment.
rayden
rayden
There was a lot of flow vis on the car during the last couple of days in bahrain, so they were clearly working on aero/performance in some capacity.
myurr
myurr
They don't even have the mandatory cameras mounted at the front. I would imagine the car that has run so far is a basic aero spec that they'll refine, but the fact it hasn't worked has delayed things somewhat.
gandharva
252
Mandrake
Mandrake
I just wonder: If RedBull really had massive massive cooling probs, why are we not seeing a totally different cooling solution in Bahrain? There's not even some amateurish cut-outs, nothing. It still looks launch spec. We were all assuming them to have totally different cooling solutions come Bahrain, but it never happened....
