It was used in testing after it was disallowed due to it's proximity to the fuel filler cap.Cuky wrote:was that 2009 Williams thing ever raced? I remember seeing it in FP on Friday, but I can't really remember if I saw it in races.
You could do something similar with an electric hybrid Andy.andylaurence wrote:If we're straying from F1, how about a gas turbine engine used to spool the turbo and the exhaust gases used to blow the diffuser? Zero turbo lag and no off-throttle issues with aero stability on the blown diffuser. All made in a garage too...
http://speedhillclimb.com/mannics-quick/
Electric hybrid doesn't have exhaust gases to blow the diffuser, turbine engine doesautogyro wrote:You could do something similar with an electric hybrid Andy.andylaurence wrote:If we're straying from F1, how about a gas turbine engine used to spool the turbo and the exhaust gases used to blow the diffuser? Zero turbo lag and no off-throttle issues with aero stability on the blown diffuser. All made in a garage too...
_hybrid_ so both combustion and electric, the combustion part could be a turbine like the Jaguar C-X75tomazy wrote:Electric hybrid doesn't have exhaust gases to blow the diffuser, turbine engine doesautogyro wrote:You could do something similar with an electric hybrid Andy.andylaurence wrote:If we're straying from F1, how about a gas turbine engine used to spool the turbo and the exhaust gases used to blow the diffuser? Zero turbo lag and no off-throttle issues with aero stability on the blown diffuser. All made in a garage too...
Of course but you could use an ERS-H motor generator solely in motor form to blow from the turbo no matter what engine revs you had. No lag and plenty of air for the diffuser at all times and with much lower weight penalty.tomazy wrote:Electric hybrid doesn't have exhaust gases to blow the diffuser, turbine engine doesautogyro wrote:You could do something similar with an electric hybrid Andy.andylaurence wrote:If we're straying from F1, how about a gas turbine engine used to spool the turbo and the exhaust gases used to blow the diffuser? Zero turbo lag and no off-throttle issues with aero stability on the blown diffuser. All made in a garage too...
