Red Bull RB10 Renault
CottrellGP
CottrellGP
Re: Red Bull RB10 Renault
Wow, the rear of the RB10 is stunning!
Dan Cottrell
Master Of Innovation!
Afterburner
Mechanics all wearing gloves isn't a good sign at all, RB "energy recovery related" once more seems to be the weakest of all top teams.
jagunx51
185
which one is more effective ......under / above exhaust monkey seat ? how are they related to diffuser-flow extraction ?
Phillyred
Phillyred
The diagram to the right isn't that simple considering the other 90% of the car contributing to the flow of air at that point.
Yurasyk
Yurasyk
Another view at the rake.
raymondu999
Yurasyk wrote:Another view at the rake.
http://110.imagebam.com/download/2z7oWg ... 486695.jpg
The car is on a wheelie trolley - there is no "rake" to be seen or talked about.
失败者找理由,成功者找方法
timbo
timbo
111
Actually the car lies on plank, so it shows well the angle between the chassis and a plank. We do not know if the wheelie is horizontal, though.
gobjb
gobjb
It is a bit curious though how, although the suspension is 'resting', the rear wheels are touching the ground while the front wheels are a good 15cm in the air.
Postmoe
Wow! Massive amount of front rake. I see lots of elipses, if they create the needed vortex to seal that... they will be unstoppable.
Jef Patat
Jef Patat
lolz, I'm sure some people will be taking you seriously though and then you'll have to show them the elipses
Jef Patat
Jef Patat
I'd noted some teams having a cooling blower attached to a hole in the roll hoop (I haven't seen it with all teams) but I never noticed that the air seems to not cool the complete compartiment. From this picture it seems all heat is coming out of the front of the sidepods, while under normal operation the hot air exits the car at the rear.
Anyone has an idea why this is? What are they trying to cool with that blower? Is that just heat from the radiators (not related to the blower)?
Juzh
161
That's just bonkers amount of rake. Button, Windsor and Hamilton may be onto something when they say RB is good in high speed.
myurr
myurr
Looks like the blower is plugged in to the hole behind the drivers head underneath the engine inlet - presumably to cool the turbo.
Owen.C93
Owen.C93
177
That is a lot of droop.
jagunx51
185
Phillyred wrote:The diagram to the right isn't that simple considering the other 90% of the car contributing to the flow of air at that point.
Ok then, lets ignore the diagram ......... which one is more effective, under / above exhaust monkey seat ? how are they related to diffuser-flow extraction ?
