I´m not even sure how to explain it further other then reapeating myself. In my opinion the problem is quite obvious if these are holes.
Holes meaning they show whatever is behind the hole. Problem is one shows the rear wing endplate the other angled so that if it were a hole it would show the mechanic´s legs in dark blue.
But it doesn´t. It shows an identical pattern but vertically reversed.
White dot and horizontal rivets.
