chimney winglet combination???
cfditya
cfditya
hello
how exactly does the chimney winglet combination work?????.....i thoght that the low pressure developed on the under side of the winglet helped suck the hot air out of the exhausts...is it true???? :?:
And the ferraris are using a different configuration when compared to others. Any views on that..
thanks
cfditya
cfditya
i read in scarbs' site about this....and he said the strong trailing vortex generated sucked the hot air.....how does the vortex help generarte the sucking power???
thanks!!
Tp
Tp
Its low pressure sucks everything towards the center of the vortex, thus extracting the hot air.
