Mercedes AMG F1 W05
atanatizante
115
Re: Mercedes AMG F1 W05
Someone said that Lewis engine/PU issue in Melbourne was due to a loose connector and according to Sky they run it on FP1 to see if everything is working fine and fortunately it was ok ...
But they also said that this PU it`ll be used at a later date back in the championship and my silly question is how could they managed to change their PU with a new one in a space of 2 and a half hours?
Jesus
beelsebob
beelsebob
85
atanatizante wrote:Someone said that Lewis engine/PU issue in Melbourne was due to a loose connector and according to Sky they run it on FP1 to see if everything is working fine and fortunately it was ok ...
Simple... they changed it. The early reports of "zomg, it's taking 12 hours to change a PU" from the first days of testing were overblown for multiple reasons. 1) The engineers had never put the PU together in the car before, and had a long check list to make sure it all went correctly 2) Practice makes everything quicker 3) Probably many of the long wait times people highlighted with it were caused by teams bullshitting to justify not being able to run for the rest of the day.
Malaysia 2014 - Friday (28.03.2014)
Gaz.
Gaz.
Maybe I misheard Ted but I thought he said Mercedes would change from PU#1 to PU#2 during Friday evening, ready for Saturday morning>
Forza Jules
ImAnEngineer
ImAnEngineer
Gaz. wrote:Maybe I misheard Ted but I thought he said Mercedes would change from PU#1 to PU#2 during Friday evening, ready for Saturday morning>
Yes, this is what happens at every race weekend. They will probably use the Melbourne race engine for the next few events' practice sessions then maybe bring it out again for the Monaco race or something. They use different engines for Friday to save them for the race.
diego.liv
diego.liv
From what i'va understood, they don't change the entire unit:
the PU is composed by 6 elements (engine, mgu-k, mgu-h, turbocharger, energy store, and control electronics) and you can use a maximum of 5 pieces of the same element
they can have changed the engine without incurring in penalty
*Edit: http://www.formula1.com/news/features/2014/1/15408.html
6th paragraph
LightningLewis
LightningLewis
Didn't Mercedes change engine cover between Q1 and Q2? From cannon to the closed one used in Melbourn?
BlackSwan
BlackSwan
33
LightningLewis wrote:Didn't Mercedes change engine cover between Q1 and Q2? From cannon to the closed one used in Melbourn?
They can't! cars are in parc fermé after exiting from the box in Q1, if I am right! :)
siskue2005
70
Yes you are right blackswan
RicerDude
27
Yes they did.
Huntresa
Huntresa
Yes they did.
Or they ran one with cannon and one without ?
diego.liv
diego.liv
I think this image is from Q3, Alonso joining the Merc pair in pit before last chance to set a lap (during which ROS claimed P3)
Me also think that Merc begin Q1 with the larger engine cover
About parc-fermè
Ferrari's Marc Gene was saying that red pit crew would have hoped to send Alonso back on track without fine tuning camber angles and whatever could have been changed by the touch with Kvyat
Malaysia 2014 - Saturday (29.03.2014)
pmneo
pmneo
AMuS wrote that they will use the Melbourne PU the whole weekend!
http://www.auto-motor-und-sport.de/form ... 24932.html
They have located and solved the Problem which was a possible fault for all Merc PUs!
230
You know i have a feeling the last issue could have been down to the water from the qualifying at melbourne.
Maybe some moisture got into a crevice and affected Hamilton's engine.
Let's hope we don't have a misfiring engine in the malaysian GP.
