langwadt wrote:
I'm a bit surprised that the Toyotas and the Porsches are in the same class, I had expected that the Toyotas
big NA engine to be far to thirsty to compete with the Porsches small turbo if they didn't pick a class with a
different fuel allowance
1. That is cuz they had even bigger engine capacity (i belive form 3.2 to 3.7 litres), low rpm range and very lean mixture. Ideal torque RPM range is in range 8-9 kRPM. Even its supercaps electric pull on accelerations, where is potential to reduce the fuel use "exponential". For example look that awesome random start from pits.TOYOTA TS040 Start n go tehnology in action ps. dont forget click sound icon on animation:
https://vine.co/v/MOtg9UnYnKe/embed/simple
I like those weight wich gave decent equality.
2. For instance PORSCHE already benefits from LPM1 R&D development. Rumours are that they test 4 cylider boxer in 911 test mule already.
