What plastic molding process?
aspetuck
aspetuck
I want to make a mold for a plastic piston mockup. It would be a solid hunk of plastic in the size and shape of a piston. In fact, there are several components I need to make molds for. What type of mold should I use? Could I CNC it? How would that impact the strength of the resulting product?
Jersey Tom
Jersey Tom
Re: What plastic molding process?
Why not rapid prototype this thing (these things)? E.g. SLA / the ubiquitous "3d printing."
Cutting molds is an expensive proposition most of the time. Better suited for larger scale production work. For one-offs, better to machine them from billet or rapid prototype (IMO)
aspetuck
aspetuck
Suppose I was interested in producing several dozen engine models, specifically of the ls7, out of plastic. What sort of mold would I use for pistons.
Lycoming
Lycoming
106
What exactly are these plastic models for?
Greg Locock
Greg Locock
237
3d printing sounds the obvious approach. In general injection moulded plastic is not suited for small production runs. Would you consider vacuum formed sheet? That can be done very cheaply, but it is a pain to build models from.
Another process you might consider is to build a wooden pattern and sandcast them in aluminium. Obviously they'd then need to be machined like a real part
Here's a 3d shop
http://www.shapeways.com/model/198434/m ... terialId=6
marcush.
marcush.
159
3D printing and all other RP processes will give a Rather Rough finish,nothing you could use for a Display methinks.
I'd consider a different Strategy here with a proper mold made of Aluminium or epoxy -with a good sufraface gelcoat.
I'm sure the Piston is very easy to Drag a mold from . The interesting Bit will be what to use for the
Actual Parts. Then ..there are some good epoxies around Maybe Aluminium Power filled and you may get a Perfect Plastik Look alike with no real Finishing work to be Performed.
krisfx
krisfx
marcush. wrote:3D printing and all other RP processes will give a Rather Rough finish,nothing you could use for a Display methinks.
You could use SLA, but it's quite brittle.
tok-tokkie
tok-tokkie
37
Consider polyurethane vacuum casting. I have access to a product development company that uses it to make prototypes and small production runs. They machine a master model, cast a silicon rubber 2 part mold then cast the urethane in that silicon mold. Urethane can be formulated to be elastic all the way to rigid.
Here is a link to their website. many products to see. (They also do high end 3-D printing, robot & cnc machining, glass fibre layup etc so not everything you see has been vacuum cast.)
http://www.skeg.com/vacuum_casting.htm
Greg Locock
Greg Locock
237
He still hasn't told us what the models are for
matt21
86
aspetuck wrote:Suppose I was interested in producing several dozen engine models, specifically of the ls7, out of plastic. What sort of mold would I use for pistons.
There is a supplier in the UK for small series molded plastic parts.
It is called Protomould: http://www.protomoulduk.co.uk/
You can directly upload your 3D-geometry as a step-file and get an offer including an analysis of feasibility.
We´re using this in our company for prototype parts.
marcush.
marcush.
159
I´d guess all this is rather expensive stuff so wouldn´t it be more cost effective to just buy a Piston and make a Display of it? gearing up for modelmaking and actual production runs of parts + inevitable development cost this all will result into something easily detected as a plastic fake ...so where is the Point?
