I'm happy If they do it. This is racing, burning fuel for the sake of performance is OK, isn't it?xpensive wrote:If they intentionally are burning fuel to store electrical energy, it makes this formula if possible even more of a mockery.
late braking would have the opposite of all of those things you list.ringo wrote:I think the energy units are turned down for life cycle reasons at this stage of the game.
As for fuel saving, I suppose this is just because everything is new and the teams are feeling out how the cars really consume over a race distance. soon enough they will know which tracks don't require it and which do.
Another reason for saving fuel is to use the rest of the rev band when required. I believe come the power tracks and high speed with a mix of slow corners we will see the engines rev high at some parts of the track. This is for flexibility and also for that little bit more power that is available up to 12000-13000rpm.
Finally, Hamilton's fuel savings in Malaysia is quite interesting, but I think this was down to his late braking style. He probably was storing more electrical energy than Rosberg. The fact that his tyres weren't giving any grip issues also improved fuel consumption in a lot of ways.
1. higher corner exit speeds, therefore less MGUH driving the compressor up to speed.
2. Higher top seeds at the end of the straights because of better corner exit. ie more brake energy to harvest.
3. Less wheel spin.
Do you have a counter-example to demonstrate why that's true?ringo wrote:Later braking doesn't necessarily mean late turn in.
xpensive wrote:What I'm most curious about is to see the energy flux back and forth between the MGU-H and the battery as this is unlimited,
I believe that's where Mercedes advantage is, the only area not regulated, while the MGU-K has been around for years and is strictly limited to 2 MJ of charging. To make full use of the ERS-systems, your MGU-H needs to harvest the remaining 2 MJ.
you could argue that late braking needs an earlier turn-in because the tyres are closer to saturation so the lateral response to steer input would be reduced. An earlier turn in could compensate for that.Lycoming wrote:Do you have a counter-example to demonstrate why that's true?ringo wrote:Later braking doesn't necessarily mean late turn in.
with the 100kg/h fuel flux limit higher rev equals to more air with the same fuel, so you have more internal friction and no extra power.ringo wrote:I think the energy units are turned down for life cycle reasons at this stage of the game.
Its right that you have larger friction at higher RPM. But you dont have more air with the same amount of fuel..poz wrote:with the 100kg/h fuel flux limit higher rev equals to more air with the same fuel, so you have more internal friction and no extra power.ringo wrote:I think the energy units are turned down for life cycle reasons at this stage of the game.
If Hamilton is able to generate more acceleration during braking then he could brake later without affecting turn in.Lycoming wrote:Do you have a counter-example to demonstrate why that's true?ringo wrote:Later braking doesn't necessarily mean late turn in.
