xpensive wrote:Right, if you double the stand-by flow to 400 Bar and 4 liters per minute for good measure, that's about 3 kW, then add 4 kW for the electronics needed and you got 7 kW or 9.5 Hp.
Mmm... The Lotus System, which I know a little about, was designed around a nominal supply pressure of 210 Bar. My best guess (I have been unable to unearth the records) is that it was powered by a gear pump (using a total loss pressure regulation) coupled directly to the cam shaft. The pump was probably a Dowty 3008 (or equivalent), so would be expected to consume around 5 HP at 4000 RPM. I think the max engine speed was 12000 RPM (so the pump was over-driven by 50% - sounds about right for F1), implying a maximum power consumption of 7.5 HP.
Your guess at electronics consumption was rather high, I think. The first system we designed (1983) ran on an uncharged dry-fit lead/acid battery weighing around 1 kg. It was designed to run for two hours, and it achieved that, completing two races. The system used for the '99 was more power hungry, but my recollection is that it ran happily in the lab driven by a 5 A, 12 V supply. That would imply 60 W maximum.
Hence I think your overall guess is not far away, perhaps between 6 & 8 HP, depending on engine RPM.
Incidentally, there was a big difference between the Lotus & Williams systems. Roughly, the Lotus system required no power to control attitude, but road inputs did consume power. The Williams hydro-pneumatic system required no power to respond to road inputs, but did consume power to hold/control attitude.
Edit:
Here is an "arty" image of the '99 system. The pump is in front.....
