McLaren MP4-29 Mercedes
onewingedangel
onewingedangel
Re: McLaren MP4-29 Mercedes
With Jenson mentioning the team struggling with fuel conservation in the long runs, and Adrian Newey mentioning that Red Bulls analysis of their competition using the available GPS data pointing to a power discrepency between fuel suppliers on the same engine - could these point to Mobil1 not having been able to optomise for the engine given whatever co-operation (or lack thereof) is provided by Mercedes?
If so is the fuel locked for the season?
JimClarkFan
JimClarkFan
27
onewingedangel wrote:With Jenson mentioning the team struggling with fuel conservation in the long runs, and Adrian Newey mentioning that Red Bulls analysis of their competition using the available GPS data pointing to a power discrepency between fuel suppliers on the same engine - could these point to Mobil1 not having been able to optomise for the engine given whatever co-operation (or lack thereof) is provided by Mercedes?
Fuel is certainly possible, more likely perhaps is the butterfly suspensions is causing some serious drag.
Obviously we don't have hands on the data but I have to wonder if it the suspension is worth it in light of the fuel issues.
There are two options as I see, either Macca are already planning to remove the suspension but this takes time, or the Macca believe the positives outweigh the negatives.... personally I would get rid of it. I think it is a bit of a gimmick.
Unc1eM0nty
Seems a bit of a leap to me putting this difference down to fuel
i70q7m7ghw
i70q7m7ghw
49
For all we know though, that rear suspension is making up for deficits in other areas. If they take it off, they could lose lap time.
I don't think the MP4-29 has relative to the rest of the field, made much of an improvement on the MP4-28. I think they'll be hard pushed to win a race this year, and will realistically find themselves either on the final step of the podium, or just behind, which is where they were last year.
It will be interesting to see if the McLaren go aggressive with the development of the MP4-29, or switch efforts to next years car and the partnership with Honda.
Emerson.F
Emerson.F
Mercedes and Petronas have made their fuel and engine hand in hand. On the Mercedes AMG site they have a very nice article. Maybe the other suppliers did not as good of a job.
http://www.mercedesamgf1.com/en/news/20 ... l-feature/
Supporting: Ham/Alo/Kimi/Ros/Seb/Hulk/Ric/Mag
Unc1eM0nty
Emerson.F wrote: Mercedes and Petronas have made their fuel and engine hand in hand. On the Mercedes AMG site they have a very nice article. Maybe the other suppliers did not as good of a job.
Marketing BS
Skippon
Skippon
Mercedes engines have never used "butterflies".
All HPP engine development will have used Petronas not Mobil fuel.
KingHamilton01
You would have to say switch to next year's car early, Making sure the transition of engines to Honda goes smoothly will mean planning early, disappointing that McLaren haven't made much of an improvement! Leads me to think they are still weak in the design department? plus something that bug's me why has button been moaning for the last 2 season's about downforce. Can McLaren not take his feedback and fix this, im not sure if McLaren have a major upgrade planned, as in new rear wing, sidepods, front wing etc! but this season's results hinge on that upgrade and I agree they will be hard pushed to get onto top step of podium.
McLaren Mercedes
twoshots
twoshots
Skippon wrote:Mercedes engines have never used "butterflies".
The reference was to the 'butteryfly' suspension not instead of throttle barrels.
I'm sure Mobil will have done fuel development possibly in prearation or in conjunction with Honda but this may be at their own facilities and not at HPP (unless they have contractual/paid for tests). But I don't think a few kW is an unreasonable difference if they haven't tested as many possible fuel blends with the specific combustion parameters of a specific engine.
Fuels development during the season is not prohibited. There are rules about what can be in the fuel but it is common for new fuels to be introduced during a season.
JimClarkFan
JimClarkFan
27
Which is what I was saying, we don't have the data to know if the positives of the butterfly suspension outweigh the negative.
It is worth remember here however that we are not talking about maximum performance, we are talking about maximum fuel restricted performance. It is clear that there exists a balance between performance and fuel usage and you can only maximise performance so far as fuel limits allow.
If you have a car that is super fast with unlimited fuel, but uses so much fuel in achieving maximum performance, it could be of little practical use in a fuel restricted formula.
When Newey says that he tracked cars using GPS with the same engines and found that they respond differently to fuels types that doesn't make sense to me. It can't possibly be true because that would mean Newey can accurately model the drag, downforce and mechanical grip of, say a Merc vs a Mclaren, using only GPS data, and then accurately adjust for that to come up with the conclusion that fuels types are causing differences in performance? I think that is wishful thinking.
Lets consider the information we do know, the obvious item on the MP4-29 causing problems with fuel is the butterfly suspension. We already know the suspension causes a drag penalty and therefore a fuel penalty.
So how can Newey come up his fuel theory, what is the most likely way he could know there is a difference in fuel performance? There are two reasons as I see it. Firstly because it is obvious and secondly because Red Bull might have got their hands on some of the Mercedes fuel and found it was more fuel efficient than their own.
I still believe that if you are going to look at why the Mclaren is so hard on fuel, you must surely look at the butterfly suspension first because it is known to have a fuel penalty because of the increased drag.
CjC
CjC
Excuse my ignorance but do we know for a fact that mclaren has a higher fuel consumption?
Just a fan's point of view
sirexilon
sirexilon
I get the point on Oil and Fuel, but knowing that they are already developing for the Honda engine, that is going to be in the McLaren for many years to come, not just 1 year like this Mercedes, could it be that Mobile didn't focus as much and they are working on next year? I think internally in the team they knew they were not fighting for the WC this year, they are just another team using merc PU's this time around, and not the support or all the initial data about engine was going to be given to them, specially since the Team is switching, Merc made it clear they will keep as mush info as possible from McLaren to ensure honda didn't get it. So this is a year at a loss, just make the best of it and prepare for the next and try to storm it.
Am I way off here?
Life long F1 fan. Always learning about all the tech around my favorite sport.
http://www.facebook.com/f1myway
FrukostScones
162
In AMuS-magazine was a suggestion Mercedes AMG fuel is not from Petronas but a special mix by some other company...
Jef Patat
Jef Patat
CjC wrote:Excuse my ignorance but do we know for a fact that mclaren has a higher fuel consumption?
If I'm not mistaken the fuel percentage in the live feed is the percentage of the maximum allowed fuel. Looking at that figure at the end of the race can give an indication. So I think we could have a fair estimate. I haven't seen a comparison though.
I'm also not buying the armchair arguments of the drag penalty of the butterflies. It has been discussed before that they may not be as draggy as they look at first sight. If they were that bad they could easily change them for arms in other shapes, arms that have no drag at all, the fact that they haven't even tested that means a lot IMHO.
In my eyes it's total bullsh** to relate fuel consumption to those suspension arms. We have no figures whatsoever so it's simply impossible to make that link. It might be fuel, less overall downforce, more drag, less aero efficiency, ...
JimClarkFan
JimClarkFan
27
Increased airflow resistance doesn't affect fuel efficiency? :?
From this website
McLaren have come up with the first real innovation of the year by creating rear suspension wishbones that are very different to what we usually see. It is the normal approach to have a horizontal teardrop design, almost parallel to the reference plane in order to minimize drag created by the suspension elements. McLaren's version though as just a bit different.
The team's approach is far away from drag reduction. Instead, the elements are rather big with a cross section similar to a mushroom lying down on its side. Before we see how it works, it needs to be noted that the design has already been cleared as legal by the FIA. This means that the entire shape is structural, as otherwise the thick fairing would be considered as banned moving bodywork as per Article 10.3.4 of the Technical Regulations.
http://www.f1technical.net/development/435
Anyway, nobody said that we have the data to do a cost vs reward analysis on the suspension. To say that the suspension doesn't affect the fuel consumption is just silly though. Doesn't matter if they aren't as 'draggy' as we first thought, it surely is more draggy than other rear ends which is kind of the whole point.
