Force India VJM07 Mercedes
Re: Force India VJM07 Mercedes
Bahrain Testing - Day 1 (08.04.2014)
jagunx51
185
" The upper wishbone outer pickup point on the rear suspension is highly distinctive, and worth further investigation. "
http://www.racecar-engineering.com/cars ... dia-vjm07/
any comment ... ??
Godius
186
Bahrain in-season testing, day 2: They are running with strakes on the wing endplates of the rear wing, first time that I'm seeing this on the VJM07:
Sutton:
vas_04614 wrote:
Godius wrote:In-season Bahrain test, day 1
http://gpupdate2.ed5.nl/large/241277.jpg
Are they testing new sidepods with more undercut or it's just illusion due to the absence of sahara logo?
Could very well be the case but I'm not noticing much of a difference because of the blackness.
Godius
186
Matt Somerfield spotted an other update:
Force India VJM07 the team have made a minor change adding some small winglets either side of the crash structure to aid in the upwash of the airflow. This is similar to solutions we have already seen McLaren and Mercedes adopt.
Owen.C93
Owen.C93
177
New diffuser too. Can't believe I've been looking at all these pictures and just realised I know one of their new mechanics, time to stop just paying attention to the Carbon Fiber.
vas_04614
vas_04614
"In hot weather we do on the other floor well because we have air upward during cooling., We do not have to open as the others in addition the panel."
Can someone explain how does this help cooling??
Godius
186
It's a translation error from google.
What Green basically is saying is that the VJM07 has a chassis that doesn't need additional cooling gills, they don't have to open up bodywork for cooling unlike many other teams at the grid. This helps the aerodynamics of the car during races in hot temperatures compared to others (additional cooling slots creates drag, disturbs airflow, etc.).
Thanks for that link, it provides a lot of information! A lot of new parts for the GP of China and for the rest of the season from what I can read. (New cooling lay-out with less cooling capacity will be introduces in Canada. They basically have a chassis that suffers from overcooling and is too draggy. The current chassis is build too conservative according to Green.)
JimClarkFan
JimClarkFan
27
What is the thinking about the rear end of the force india, the area surrounding the exhaust seems to be considerably chunkier than other cars?
aleks_ader
90
I believe those lower picture (2nd) its from preseason testing. Firstly they here were testing air-air intercooler and finnaly they decide to alterate from Melbourne to race air-water-air one (1st pic) . But could i be wrong.
Here is racecar magazine and article where are "reaveled" many usefull details form that car..
Summary of the most interesting stuff from article:
What a shape and usage of material on that hub assembly, pure engineering porn/skills. I believe those part must be 3D printed. Look toward "naked" non covered upper shingarm join point.
Covered upper wishbone join point with flexible carbon "cover"
Huge (probably for hydraulics) "gearbox" cetral radiator compare other Merc teams.
Godius
186
JimClarkFan wrote:What is the thinking about the rear end of the force india, the area surrounding the exhaust seems to be considerably chunkier than other cars?
I'm totally not an aerodynamicist so I like to know the answer to this question as well. All I know from reading the articles is that they have overdone it with the cooling of this car, they will introduce a more tightly packaged chassis in Canada.
marcush.
marcush.
159
FI and Williams both have done the sensible Thing and erred on the save side with their cooling package ...and have hauled an awful lot of Points in those first races when others struggled for reliability.
The clever bit here is they have bagged those Points AND know exactly how much cooling capacity they can get rid off which is Efficiency and less weight without sacrifying reliability....
How could they start overweight into testing and now already be in a Position of having 10Kg of Ballast....I guess their test layout was even more on the safe side?
Sidhartha.techie
Sidhartha.techie
They are talking about reducing the drag, does that mean they will be able to achieve more top speed ?, they allready are faster than everyone else on the straights.
vas_04614
vas_04614
Sidhartha.techie wrote:They are talking about reducing the drag, does that mean they will be able to achieve more top speed ?, they already are faster than everyone else on the straights.
They think Williams is faster but yeah in Bahrain they were faster.
rscsr
51
aleks_ader wrote: What a shape and usage of material on that hub assembly, pure engineering porn/skills. I believe those part must be 3D printed. Look toward "naked" non covered upper shingarm join point.
http://www.racecar-engineering.com/wp-c ... eejay3.jpg
I think that it is more likely that the hub is cast (with the model printed and lost).
