Yes, this was justa crazy idea, I like to think loud sometimes. Everybody is using 7-8 gears and the ones using 7 will probably now use 8th in China. The points you raise are some of the very obvious drawbacks of the idea. I expect it not to be worth it at all.
I also don't know enough about the internal construction of gearboxes, so basically I wanted to know whether this trick could in real life, with an ad-hoc design, achieve mostly two things:
a) Reduced rotational inertia in the gearbox.
b) Reduced dimensions of the gearbox, in particular shorter axes as mechanisms that before had to extend beyond all gearplates now can exists in the space that the fake gearplates, as they only need to reach 6 gear plates.
