The new nose was used by both drivers in FP1.
is that why merc engine use log type manifold, because the turbine donot much rely on kinetic energy from exhaust gas ?Pierce89 wrote:If they have multiple shafts, they can run the turbine and comprssor with only an electrical connection like i've been crowing about in the general engine thread. This would allow the turbine to run in full power harvest at all times independent of compressor speed. You would exchange the slight inefficiency of an electrical connection compared to a shaft but you could harvest more energy in the first place because the turbine and compressor don't encumber each other. More exmhaust recovery and much finer compressor control.
Don't think so, otherwise they would have already reverted back to the old nose.ab_f1 wrote:Guys, New here and first post, but a quick question. Could it be that the balance issues for Hamilton are caused by the new nose.
Probably. Its the first time they have run it so they need to understand how to adapt their setup.ab_f1 wrote:Guys, New here and first post, but a quick question. Could it be that the balance issues for Hamilton are caused by the new nose.
