Ok so the FIA is presented with multiple challenges for the future when it comes to F1 cars.
1. Reduce fuel consumption to make the sport more environmentally friendly in the eyes of the public.
2. Keep downforce levels at an appropriate level to stop cars becoming to fast.
3. Increase the abysmal rate of overtaking in current F1.
I have an idea that can help all three with one simple rule change. The FIA should increase the span of the rear wing to say the width of the widest part of the rear of the car (or a little less to stop the rear wings hitting each other like the front wings did before). Then to keep downforce levels to current levels reduce the chord of the rear wing to match the required downforce levels. This will reduce the induced drag massively because of the huge increase in aspect ratio. Current F1 rear wings have horrible aspect ratio's. This results in massive wingtip vortices and induced drag. By increasing the span and reducing the chord you reduce the size of the wingtip vortices reducing drag and reducing the disturbance of the air for cars behind. With a reduction in chord, the camber will also have to be reduced to stop the wings from stalling. That means for a given surface area of the wing the airflow will have less "work" done to it further reducing the turbulent air for following cars.
Therefore with this simple change downforce levels can be kept to required levels, drag is reduced and the air behind is less turbulent for following cars making overtaking easier.
