Hello everyone,
This is my first post on this forum. I would just like to say thank you for having me aboard, this appears to be an amazing resource for many.
My Project:
1993 Honda Civic 1.6L Turbocharged for use in Time Attack
Question:
I am mounting a Fiber Optic Pressure Transducer that is made by the company Optrand. This Pressure Transducer is intended to operate at 350 degrees Celsius continuous operating temperature maximum.
There are really only 2 locations where I see feasible to mount this transducer, that is in between the exhaust valves (plenty of room) or in between the intake valves. This Transducer is essentially a probe, it is very small and is drilled into the head.
My concern is that if the transducer is mounted in between the exhaust valves, the temperature will get too high and it will burn the transducer out. My experience is that exhaust valves reach an average of 650 degrees C, while the intake valves only reach an average of 250 degrees C.
I understand that the quenching distance of gasoline is roughly 2mm. This probe's mounting instructions call for a 1mm diameter window into the combustion chamber. So the transducer itself is never actually exposed directly to the flamefront. This should result in a significant reduction in temperature.
On the Intake valve side, although the temperature will be lower, there is not enough room to drill straight through from the top of the cylinder head to the combustion chamber, instead the machining will have to go through the intake port on the way. Because of this I will run into a sealing issue because the intake port is being drilled through, the incoming air charge now has a means of escaping via the machined hole to the upper cylinder head. Also the pressure transducer is placed at the end of a braided line (1.5m) and this line will be blocking some of the intake stream.
My real question here is will the transducer survive being mounted between the exhaust valves? Does anyone have any simulation software that they could run this through quickly?
Many thanks
