Mercedes AMG F1 W05
RZS10
359
Re: Mercedes AMG F1 W05
Am I mistaken or did Mercedes propose to build that louder exhaust tip for everyone? Or do they just have a solution that everyone could build/adapt themselves ... because that exhaust might be optimized for the Merc engine end their specific exhaust layout, giving them more power and/or other advantages, the 'being louder' part just being a side effect they can use to sell it to the FIA :roll: :D hehehe
It's just a simple Megafon over the last 200mm of the Exhaust Tip. Thats the same for every Engine and i hardly believe one Manufacturer would gain advantage of it.
It's rumoured to be a very small power gain, but yet again that's the same for all 3 Engines. And to add, that solution is just 1 of Many. It's being tested now because it's easy to build. Maybe we will see a completely different type in the End.
OO7
OO7
171
gandharva wrote:Barcelona - In-season test day 1:
http://abload.de/img/trumpet48jen.jpg
New Monkey Seat by the looks of it.
bonjon1979
bonjon1979
30
what is the 'snorkel' at right rear tire for ?
Weird.
bonjon1979
bonjon1979
30
Looks like there's something protruding where the rear wing meets the diffuser.
astracrazy
astracrazy
31
best picture i could find of these snorkels
Steven
Owner
It looks like they are cooling outlets of some sort. Here's another pic from today
More in our gallery http://www.f1technical.net/gallery/2014 ... est-13-may
astracrazy
astracrazy
31
using the hot air from the brakes?
Holm86
247
Pretty sure they are chimneys for hot air exit from the brakes. The way they are angled, they look to me as if they are trying to guide some air into the rear tires wake.
I don't think they just redirect / energize the Air coming to the Brake Ducts and not actually used to cool. Using Hot air from the Brakes wouldn't make really sense, plus it is harder to achieve.
The Air going into the Brakedrum, going through channels, getting distracted by the actual cooling Surface and then redirected out of the Brake drum wouldn't make much of an effect imho.
RichardF1
astracrazy wrote:using the hot air from the brakes?
It looks like they have moved the exits higher to alter airflow by the winglets and floor. Could there have been disturbances in airflow when the exits were located in and around the winglets between the rear wing and tyre? Wondering if this improves wake and therefore diffuser efficiency?
WWKD- What would Kimi do?
SparkyAMG
First post here...
I'm an enthusiast rather than an educated engineer, but it looks like the new 'Snorkel' is angled towards the top of the Endplate slots. Would there be any benefit to blowing the slots to aid upwash and increase diffuser efficiency?
Barcelona Test Session - Day 1 (13.05.2014)
gandharva
252
They are definitely using the new exhaust exit. The copied air exit looks poor with those two huge holes. I think the new brake duct pipes are supposed to route all hot air away from tires. Hence the outlet so far back on the car. Rear tire wear is crucial with new engines and this could help to stabilize tire temperatures.
Richard
Richard
I wonder if it is shaped like that to exploit the loophole that allows brake cooling ducts. In reality it'll be an aero flow conditioner that just happens to have some air than might come from somewhere near the brakes so it can pass the regs?
