Red Bull RB10 Renault
Juzh
161
Re: Red Bull RB10 Renault
Mandrake wrote:It might be the picture and angle, but that diffusor looks super tiny?
It's the picture and the angle :wink:
Everyone is maxed out on diffuser dimensions. there's absolutely no reason not to be. It's pure performance with virtually no drag penalty. Otherwise we wouldn't have these monstrosities back in 2010
Mandrake
Mandrake
I went through the old pictures and you are right. Strange how it just struck my mind......maybe because my own car has a larger diffuser than the F1 cars :D
AfroDude41
AfroDude41
View from new nose camera in Monaco
They took out the upper monkey seat, but kept the narrower bodywork from Monaco.
Robbobnob
Robbobnob
33
Anyone know if the insulated inlet at the bottom is the input form the exhaust manifold or otherwise?
Robbobnob
Robbobnob
33
Sevach wrote:http://cdn-2.motorsport.com/static/img/ ... 2/s1_1.jpg
They are also running a traditional grill vented end plate compared to the venturi slot solution they were experimenting with.
jagunx51
185
is this new ?
not seen from behind..... or perhaps they just test it
http://www.f1fanatic.co.uk/wp-content/u ... 2014-8.jpg
Owen.C93
Owen.C93
191
http://seven.collective-b.org/wp-conten ... 6_rear.jpg
RBR do run a shallower diffuser than most but they go for more rake. It's one of the reasons they can run so much rake before stalling.
Juzh
161
In what way is shallower diffuser beneficial to this?
I don't see how it would be benificial either. It only would require stronger vortices around the floor area to properly seal the floor, plus it would raise CoG.
Yes it is
Owen.C93
Owen.C93
191
It helps stop separation whilst still having a large expansion ratio.
The RB difusers tend to use the rear wheels in combination with the trailing vortex from the wheel cut outs on the floor to creat the diffuser "walls."
flyboy2160
flyboy2160
84
Owen.C93 wrote:...
Would you explain this further or draw a picture?
