http://globoesporte.globo.com/blogs/esp ... ixo/1.html
The hellicopter cam pretty much clears Felipe.
Put him at the back facing the wrong way.Bob Brown wrote:You would think that they have a better penalty system than putting a backmarker at the back anyways.Morteza wrote:Max Chilton has been given a three-place grid penalty for the Austrian Grand Prix after colliding with Marussia team-mate Jules Bianchi.
Yes, I'm serious. And I'm not new to F1. They have changed the amount of points a certain position is worth but for the last 24 (yeah, sorry not 25, I was wrong on that one) years all season results have counted to the final point tally.60DShim wrote:lol seriously? Are you new to F1? I can't fathom how many arguments I've read about how a championship was decided based on the points scoring system. If it was so great, why do they keep changing it?the user wrote:Usually simple is better. And it has worked ok for the last 25 years.
How many times has it changed in the past 25 years?
Mass'a best chance certainly was when Vettel ran deep at the T10 hairpin (Lap 63-64?). And Massa was out-dragging Vettel heading onto the stratight. I saw Massa's rear wing flip open once they crossed into the DRS zone and it looked like Massa was going to easily take the position. Then, for some reason, Massa's wing was closed while he was dragging with Vettel down the straight. The cameras didn't catch where the wing closed though. But at that point Massa wasn't going to be able to effect a pass because he had full rear wing? Did Massa hit his brake at some point deactivating his DRS? Either way, lost opportunity there.ringo wrote:Good win by Riciardo. =D>.... Massa proved again why he's not a #1 driver. Not because of the crash, but because of his failure to get vettel....
That is how fast a Mercedes-powered car isJuzh wrote:mnmracer wrote:https://vine.co/v/MD07j6lMTeW
Actually he did, but then retired half a lap later.Mandrake wrote: Today Hamilton appeared to be quicker but could not get past.
1. One still proves everything. 2. The same type of stewards that for two collisions in one race gave a reprimand but at worst 50/50 (OK I need to re-watch itSevach wrote:The stewards agreed.F1 addicted wrote:https://pbs.twimg.com/media/BpoqzP6CQAAkvM-.jpg
Thanks to the slow pit stop of rosberg. On track he could not pass, even though some of you rumor him to be several tenths quicker....dans79 wrote:Actually he did, but then retired half a lap later.Mandrake wrote: Today Hamilton appeared to be quicker but could not get past.
The issue is that Rosberg out braked himself. Had he actually tried to stay on track he would have had to make a much sharper turn, and slow down much more significantly. Instead, he made nearly no turn, and floored it. Had that mistake happened somewhere where there were walls, he absolutely would have lost the position, no question. For that reason, I'd suggest that he absolutely did keep the lead by using the run off area, and absolutely should have been at least forced to give Hamilton the position.Mandrake wrote:The chicane incident is nothing. Lewis was not alongside or even close to pass there, Nico just braked too late. Had he tried to make the chicane, he would have slowed down massively and blocked Hamilton. Would have been a drag race to turn 1 which I'm sure rosberg would have used to stay in front.
Actually, he did get past, he just retired shortly after.In Spain and Bahrain, rosberg was the faster driver but couldn't get past Hamilton. Today Hamilton appeared to be quicker but could not get past. Tough luck vettel would say. Only the botched pitstop for rosberg opened the chances for Hamilton to pass.
You do realize Lewis lost 0.6 seconds during the first stop right? He came out 2 seconds back and then proceeded to run him down before the second stop.Mandrake wrote:Thanks to the slow pit stop of rosberg. On track he could not pass, even though some of you rumor him to be several tenths quicker....dans79 wrote:Actually he did, but then retired half a lap later.Mandrake wrote: Today Hamilton appeared to be quicker but could not get past.
