PASSION
The challenge to build the best trackday car in the world.
There are many ways to describe „Passion“ the easiest way for the reader to understand is probably to explain it as the passion being the foundation. Its the only thing I had in the beginning, a passion to build the ultimate car, car faster than any other, everything else came later. My passion was fuelled by my father, engineer, businessman, kart driver and coach. That was even before I was self-aware of my passion. Its always been there, but every year it keeps getting bigger, the more you learn the more you want to achieve, there is no end. When you are truly passionate about something it becomes a curse, you start projects, but you learn in a pace that makes the original idea out-dated, then you start another, and the circle continues.
The beginning is the hardest, having wild ideas, too wild to tell anyone in the fear that they will think you are insane. Some people will never get over the fear I guess, others just dont have the ideas, ive been lucky, I had help. There have been several projects in the past, they have failed. The reason: Fear of others seeing you fail.
That fear leads to not asking for help, its unprobable that an uneducated 26 year old can complete a project of this magnitude without running into problems, add the fear of asking help and you´ve got a failure. This post is here to remove that variable in the equation, an attempt to keep my Passion alive through your comments and feedback.
The First Concept:
Any advice on how to improve the aerodynamics of the car very welcome, Dont get into too specific with the dimensions of things, its a first concept and should be treated as such, feel free to ask for additional images of specific areas.
