Tyre Warmer Ban 2015
FrukostScones
162
Re: Tyre Warmer Ban 2015
puh, avoided that one. No ban of tyre warmers in 2015!
http://www.auto-motor-und-sport.de/form ... 16458.html
I could see a lot of sets of tyres being accidentally left near the heaters in the garage. Or outside in the blazing sun, with a mirror or two just happening to be nearby shining on the backside of 'em...
mikeerfol
68
PhillipM wrote:I could see a lot of sets of tyres being accidentally left near the heaters in the garage. Or outside in the blazing sun, with a mirror or two just happening to be nearby shining on the backside of 'em...
It's confirmed it's not going to happen ;)
Cam
45
Moxie wrote:I will add that the real problem here is not the tire warmers, but the tires themselves. As F1 has insisted that Perelli supply such fragile tires I suppose the argument can be made that the warmers are in fact a safety requirement.
Independant wrote:"If we had been asked to make tyres that didn’t degrade because nobody wanted pit stops, then that’s what we would have done. As it is, we just did what we were asked to do."
Pirelli can make anything they want - all they need is to be asked. But apparently not tyres that don't need warmers?
Old Hembrey again eh? I'm going to start calling him "Cleopatra" - queen of de-nile.
― Socrates
mikeerfol wrote: It's confirmed it's not going to happen ;)
Which is why I said 'could', not 'can' ;)
l4mbch0ps
l4mbch0ps
Cam wrote:Pirelli can make anything they want - all they need is to be asked. But apparently not tyres that don't need warmers?
It will always be beneficial to start a run with your tires closer to their operating temperature than ambient. The behavior of the compound will always be engineered to perform optimally in a temperature window in line with what they will see at speed, and so they will always perform sub optimally outside of that window - for example, ambient temperature.
Cam
45
Here we go. So over in the the other thread we have peeps saying F1 needs to be road relevant now, hence the new engines and desire to attract more manufactures. What is relevant about tyres that need to be warmed before using?
No wonder this sport is confused. You guys can't have it both ways.
― Socrates
McMrocks
McMrocks
32
Cam wrote:Here we go. So over in the the other thread we have peeps saying F1 needs to be road relevant now, hence the new engines and desire to attract more manufactures. What is relevant about tyres that need to be warmed before using?
You could try to heat up your normal tyres in the winter instead of using snow tyres when there is no snow. :wink:
No seriously: tyres that last less than 100km aren't road relevant anyway. F1 can't be 100% road relevant.
Engines that rotate with 10000rpm+ are also NOT ENTIRELY road relevant but just up to a point
Cam
45
So we can be 30% relevant? How about 52.6% relevant? You're either relevant, or you're not.
Relevant Definition wrote:having significant and demonstrable bearing on the matter at hand
What's demonstratable about tyre warmers on road cars? What's significant about that?
Unless F1 can prove it has significant and demonstrable bearing on the matter at hand (road vehicle manufacturing), then anything else is malarky - IMO.
― Socrates
Aleexi
Aleexi
Couldn't the teams just go around this rule by heating up the garages and have some other room for mechanics? :D
