PhillipM wrote:Edax wrote:
Indeed there is a lot of stuff around. But the stuff I'm using is PTFE particles with an acrylic binder and solvent, so not oil based, and the end result is (supposed to be) a highly packed dry layer.
Well, just as an experiment, you can buy acrylic binder from most art/paint shops, and PTFE powder from many locksmiths. If you wish to try it, see what the durability is like of PTFE staying bonded to a thin surface coating of acrylic binder - even when it's acid etched, it's not good. Especially if it's being hit by debris at 200mph. The thing about a non-stick powder is, it works both ways
![Smile :)](./images/smilies/icon_e_smile.gif)
Well I'm not doing 200 on my bike and the chances of me accidentally cycling into a hurricane are pretty slim, so I don't really worry about 200 mph debris.
I agree that such a coating (if used) would not be durable, but it would help. And if you look how how the cars are for instance affected by a blocked slot in the FW, then I'd say better than nothing is still worth doing. And they only need to work for a couple of hours.
Etching indeed wouldn't help, no need to try it. But if you want to go really fancy you could graft it on there. There are some curable PFTE composites around which really form a coating. But I guess that would probably affect the non-stick properties somewhat.
Who knows perhaps they are just using turtle wax with some coloring added, to avoid the embarrasment of using an off-the-shelf component, and to have the competition (and us) guessing about a miracle "speed coating".
n smikle wrote:Why do you hate silicone oils?
OT.. Worked with ultra high vacuum applications. In vacuum it is agressive, mobile and non-cleanable. If you get some silicone contamination, then your equipment is a write-off.
