I don't think Mercedes is really worried about racing without the FRIC system. Otherwise we would have heard much more fuss from the team. About tire wear, FRIC is more about creating a stable platform under braking and highspeed changes. I don't think tyre wear is linked to FRIC. Because last year we had Mercedes had a FRIC system and the tyre wear was still bad. I think suspension geometry, weight balance, gearbox ( torque control out of slow conrners) have far more impact on tyre wear. FRIC is like TC, its help the drivers and gives them confidence. But last year Lewis stated that the FRIC system hampered his feel under braking. So maybe his braking could even improve without the FRIC system.ringo wrote:Could be very integrated into the car. Not sure where you get your time estimates from though. How did you come up with 30 minutes?gilgen wrote:To run the car without fric only requires the hydraulic link to be isolated. A job that might take 30 mins at the most. Others who disabled their fric, were able to continue running, so why not Merc?kooleracer wrote:
After the spin of Lewis, Mercedes stripped the whole car it took 5-6 hours Mercedes said it was an engine change but I think they would have removed the FRIC system and run the car without to see how it behaves.
I think the car can be faster without it. This assumes Hamilton is probably feeling more confident without the FRIC, but as said before there may be drawbacks with respect to race pace and also tyre degradation. Remember how bad mercedes used to be with tyre wear?
How much time do YOU reckon it would take to open a connection joint and to put a blanking cap on it?ringo wrote: Not sure where you get your time estimates from though. How did you come up with 30 minutes?
I hate to shamelessly bump this post of mine, but I really want to know.NewtonMeter wrote:Was that in the article? My german is so bad, I understand more with google translate (which itself is pretty bad).MercAMGF1Fans wrote:Apparently the car is faster without FRIC.. dunno how, but don't care!pmneo wrote:Amus wrote that Merc will not run FRIC at Hockenheim! (Source: http://www.auto-motor-und-sport.de/form ... 53531.html)
So i would guess that they ran without FRIC during testing ..
It may also mean faster over one lap, but slower over a race distance. Or vice versa. Just playing devils advocate here.
Thanks for that.pmneo wrote:I am German and there is no hint in the Article, that the car will be faster withou fric!
They write that experts are expecting a higher handicap on slow tracks than on high speed tracks for all fric powered cars.
They also say that all teams, except the small ones, are running fric ... Just not at the level like merc or rb
Sorry wasn't replying to the article, just replying in general..NewtonMeter wrote:Thanks for that.pmneo wrote:I am German and there is no hint in the Article, that the car will be faster withou fric!
Would Mr. MercAMGF1Fans share with us whence he obtained this information? I more curious than doubtful, let it be known.
Ah, thanks. Are you referring to Paul Bennett? I see he works at the team, which is pretty cool. So he would probably know.MercAMGF1Fans wrote: Sorry wasn't replying to the article, just replying in general..
my source..
https://www.facebook.com/photo.php?fbid ... =1&theater check the comments on the side..
Yeah, those are the only two reasons for having it on the car. So taking it off must disadvantage them in some way - otherwise it would never have been on in the first place. That is a fact.SiLo wrote:If its on the car you can be sure it's there to either meet a regulation, or make it go faster. And seeing as this seems to break a regulation, or at least cover a grey area, you can be damned well sure its there to make it faster (in some sense).
The car should be well below the weight limit with and without FRIC. I do not think they can profit from more balancing as the car is already balanced very well and as the system is installed very low in the chassis, there is no profit from deeper COG.CBeck113 wrote:They are also removing weight from the car - this can certainly be an advantage for a hot lap too.
Hmmm...you make a very interesting point. I wonder if this might be it. It would make sense at first glance, because all else being equal, lower weight will give you more performance as you can put more ballast where you want.elf341 wrote:There is a third reason, apart from performance and compliance: wider peak-operating windows. This relates to the task through free practice of adjusting car settings from the the simulator-optimal values to true-optimal observed at track.
Components which both produce better correlation of sim-optimal to true-optimal, and also components which have lower performance sensitivity to parameter changes may be more desirable than those which don't have that quality, but have higher peak performance.
Ross Brawn in the past complained on the W03 that they had very peaky performance characteristics (e.g. china 2012 where they hit the sweet spot) - it's obviously a nightmare to develop in these kind of conditions.
I don't think that running with or without FRIC is a huge difference for the Car itself ... Amus wrote in the Article, that the Mercs where running most of Winter Tests without FRIC on board ...Bei den Wintertestfahrten wurde meistens ohne die Technik gefahren.
