brutus wrote:If it's impossible, how do RC cars even exist? It's obvious that a lag in response means the driving will never be optimal, but it's possible. If nothing else, at least straight line speeds should be much higher.
The RC cars I know aren't driven over kilometers away from the person who controls it. Also the RC cars I know don't need to send video over.
As for the signal decaying, that's not an issue with decent equipment
I would say an telecom provider would have good equipment, but once you are in an area with less coverage, your connection becomes incredibly unstable.
And comparing with RC cars, well, this formula would be much faster
Making an 20ms delay much more noticable than on a slower, smaller RC car.
And compared to virtual reality, i don't get why people keep saying that real cars on a real track it's the same thing as a game.
Because it is a competition on a large scale RC car that you have to witness from grandstands. This same remote controlled action can be seen in leagues like iRacing. The only difference there is that you aren't meters away and can only see a small portion of the track for an astronomical entree fee.
if that were the case, how come people use RC cars, planes, etc, instead of simulators?
Hobbies. Which also is why simulators are played; as a hobby.
This could actually have more potencial for creating new technology for the auto industry because it wouldn't be limited by regulations. For instance, you can't develop a two stroke/direct injection to run in WEC, and you can't have a diesel in F1, even if you're convinced they would be better.
F1 never had any road car relevance, and probably never eve will. You need to look more into prototypes to see this road car relevance. I cannot think of a single thing in F1 that later found it's way to road cars.
George-Jung wrote:Drivers need to feel what a car is doing..
Because if a car starts to slide, they will immediately feel that, before they actually see it..
And if I'm correct, current FFB effects are completely wrong. Not to mention this also is data that needs to be sent in real time. Which will also happen in a delay.
