hello guys,
i need please a free and good CFD software to study a design, i am using windows xp and my design will be made by solidworks or catia
i didn;t really get what you mean here and what should i do ?!Jersey Tom wrote:I was thinking about downloading some Windows binaries of OpenFOAM just to play around with... but you'd think the best option would really be to just get the source and compile it yourself. I'd have to guess that code optimized to whatever processor you have (e.g. if you can take advantage of AVX, AVX2, or AVX512...) would make a noticeable difference in performance!
does this study aerodynamics around the car ?machin wrote:I've been using Khamsin (http://www.hibouscientificsoftware.com.au/) which is a plug-in for google Sketchup (free), which uses openfoam. It has a 30 day free trial period. I'm using it on Windows 7... not sure about XP. You can import Solidworks models into Sketchup. Took me a few days to get it working, but there's plenty of helpful posts on this forum (search for Khamsin Virtual race car championship).
Yes, it'll give you drag and lift figures, from which you can easily calculate the flow coefficients, if that is what you're after.firasf1dream wrote:waw ! seems awesome thanks a lot![]()
and does it give me all the calculations i need around the car ?
The trick to getting viscous CFD to run in reasonable times on personal computers is to have a program that utilizes adaptive meshing. The program will decide how fine the mesh needs to be. I've used this with Nika/ProEFD/Flowsim for years. I sometimes override this for a special need. For instance, when analyzing aero-optical distortion over a sensor window, the optics guy wants a very small uniform mesh over the entire window. But for most everything else, I just set the starting grid to some size to get the calculation running, then let the program add or combine mesh blocks as it sees fit. This saves a huge amount of time over requiring a small mesh where you might not need it.machin wrote:...
I've been doing some analyses of simple vehicle shapes with 0.01m mesh size (on the surface of the car) and it takes about 4 hours to do 500 iterations. That's on a little laptop, so would be shorter on a better machine. I just leave the machine on overnight doing the sums.
