Lotus E22 Renault
SectorOne
Re: Lotus E22 Renault
Just saw Maldonado oversteering in Eau Rouge and it looked to me the hot air exit at the back is asymmetrical.
Like a big cannon on the left, a small on on the right side.
Am i seeing things?
It caught my Eyes too. So much asymetric things happening on that Car. If i am not mistaken from what i've seen the Exhaust including the Rear Wing support, the Nose, Hot Air Exit and the top of the Sidepods are not mirrored. Aside from the Nose, I wonder what they want to achieve with that.
SectorOne
had a better look now and sure enough, left hot air exit is about twice the size.
Easily the ugliest formula 1 car in modern times. I just can´t see how these asymmetrical ideas are any good.
Godius
186
Here's a screenshot from reddit
http://www.gfycat.com/RedZestyHyena
scarbs
scarbs
393
The left sidepod houses the turbo intercooler set up.
SectorOne
Doesn´t this affect the aero quite significantly? I mean it just looks so wrong.
One side basically blocks of the entire side while the right is relatively slim.
Edit: also is that a bigger hole on top of the sidepod?
f1316
f1316
82
Could it be that every bit of asymmetry downstream is all to compensate for the effects of the nose concept? I.e. the airflow is already asymmetrical because of the nose so they're trying to even it up with asymmetrical bodywork.
If so, seems like a lot of effort for a slightly higher nose...
timbo
timbo
111
f1316 wrote:Could it be that every bit of asymmetry downstream is all to compensate for the effects of the nose concept? I.e. the airflow is already asymmetrical because of the nose so they're trying to even it up with asymmetrical bodywork.
Don't think so. There were plenty of asymmetrical cooling outlets on the mid-00's cars (Williams and Ferrari most notably) with perfectly symmetrical noses.
The rear end might also be for the testing only, to check both configurations at once.
Holm86
247
McLaren has had their pieces of asymmetric bodywork as well. Both asymmetric sidepod intake and outlets, and asymmetric exhaust outlets.
JRodrigues
JRodrigues
Could it be that it provides more downforce to the left side of the car (since it is a clockwise track)? Like in NASCAR where the cars are lower on the left side.
mbchc
mbchc
JRodrigues wrote:Could it be that it provides more downforce to the left side of the car (since it is a clockwise track)? Like in NASCAR where the cars are lower on the left side.
You mean Nascar on an oval ring? They are meant to constantly turning left, but not F1 cars. AFAIK teams build up their car in half and let the computer calculate the rest. Since the car is identical , and if the car with a side only more downforce, I believe they will lost a lot of time on the straightaway. :roll:
Mercedes AMG Petronas
AMG|||
lio007
316
A closer look to their asymmetric bodywork:
henra
henra
53
lio007 wrote:A closer look to their asymmetric bodywork:
http://img2.auto-motor-und-sport.de/Lot ... 805524.jpg
Wow! That's quite an asymmetry!
Unfortunately past experience let me firmly believe that Air tends to be rather stupid an not to comply with too clever designs....
In contrary, Air, feeling stupid, might get pi**ed and fight against it. :mrgreen:
Per
Per
35
What strikes me on that pic is the mechanical design of the upper wishbone. At FSAE, design judges would never stop telling students that there is absolutely NO excuse for having suspension rods in bending.
So were the FSAE judges exaggerating or have Lotus come up with a poor design?
This is F1, aero trumps everything.
Unfortunately.
