https://www.youtube.com/watch?v=gLRLhZJsCh4
Sounds pretty good.
If by 'execution' G-G - you mean certain operatives involved might have been more motivated to get it working well..gruntguru wrote:Problems were mostly about execution rather than the H-16 concept.
Drive shaft seals maybe?auaq wrote:What's with the presence of oil on the two lower exhausts?GitanesBlondes wrote:The Lotus 43 an the BRM H16.
http://fc02.deviantart.net/fs70/f/2014/ ... 7vf7wu.jpg
Sure looks like something flung out of the trans.. ..& wonder how much went down on the track?TurboLag wrote:Drive shaft seals maybe?auaq wrote:What's with the presence of oil on the two lower exhausts?GitanesBlondes wrote:The Lotus 43 an the BRM H16.
Thanks JAW. The article mentions Corliss Valve as a means of intake throttling. More efficient than a butterfly valve. Do you have any good links/diagrams describing the Corliss Valve as an ICE throttle. (I did find many references to variable cutoff steam engines.)J.A.W. wrote:This final piston design built by R-R, a real aero-monstrosity - burned petrol at 342 imp gal/hr at take off rating..
http://www.flightglobal.com/pdfarchive/ ... 00626.html
