Here is Ricciardo's 360 km/h.
[youtube]http://www.youtube.com/watch?v=BR8kkwJ2d7M[/youtube]
Funny is that most of the kinetic energy is still wasted. The front breakes have to "destroy"(convert kinetic to thermal energy) more kinetic energy than the rear brakes. Having said that, 320bhp aren't a THAT outrageously high amount. But it is only achievable if the teams are allowed to recovery energy from the front wheels too.SectorOne wrote:Just continue to develop the ERS system. KERS went from 80 to 160 in four seasons it ran so double it again in another four-five years
320 electric horses plus some from the ERS-H for good measure.
Land driven rockets basically.
+1PlatinumZealot wrote:I say increase the fuel flow limit. That is the real enemy here.
More fuel onboard equals, heavier car equals slower laptimes. Also heavier car means more stress through the tyres. Also the teams use simulators to get the optimum fuel levels for the start.andylaurence wrote:If they're not short on fuel, why do they use these fuel-saving techniques? They change engine maps and lift/coast to save fuel.
Take a look at the Rotax Max Senior kart class, those currently drive without front brakes (used to have them a few seasons ago and didn't have them before that). Sure, I out brake them like crazy in a KZ1 which has front brakes and adjustable balance. But that was the point of my suggestion: gain more power by sacrificing a bit of braking (when balance is set more to the rear) or gain drivability and loose some power (when balance is set more to the front). It's an engineering challenge for which they could find and optimum, which probably differs per track and rewrites more adaptation from the drivers = bigger challenge.Belatti wrote:You just cant brake with the wrong brake balance. Corner entry speed would be awful and tyres wont last
What kooleracer said. Also, fuel consumption in race is an estimation that may vary a bit. Also, what if there´s a SC? On tracks like Monza where it´s not rare to deploy some SC teams may hope there will be a SC so the put less fuel to gain some weight/time. If then there´s no SC, you need to save fuelandylaurence wrote:If they're not short on fuel, why do they use these fuel-saving techniques? They change engine maps and lift/coast to save fuel.
Not the same as a kart with no aero pitch sensitivity and larger tyre patch vs. weight ratio when you have to slow down more than 200kph. Braking distances would triplicate and rear tyres would be destroyed within few laps, plus the cars would be unstable entering fast corners.NTS wrote:Take a look at the Rotax Max Senior kart class, those currently drive without front brakes (used to have them a few seasons ago and didn't have them before that). Sure, I out brake them like crazy in a KZ1 which has front brakes and adjustable balance. But that was the point of my suggestion: gain more power by sacrificing a bit of braking (when balance is set more to the rear) or gain drivability and loose some power (when balance is set more to the front). It's an engineering challenge for which they could find and optimum, which probably differs per track and rewrites more adaptation from the drivers = bigger challenge.Belatti wrote:You just cant brake with the wrong brake balance. Corner entry speed would be awful and tyres wont last
