I´m not sure about the effects the temps will have on the car aquaplaning but i can definitely see the tires cooling off too much but i´m sure you can just shorten the slow zone to have negligible effect on the tires.cma wrote:In this scenario could a 60kph limit allow tyre temps to reduce so much the ride height lowers a lot causing the car to aquaplane easier with the plank in the water until the temps come back up?
A higher nose would have went under the tow truck in exactly the same way a low nose did.Ali F1 wrote:A higher nose would've made contact with the crane and then sent him up in a skyward trajectory (Less chance of a direct blow to the head) or it would've completely dissipated the energy in the same fashion as a tyre wall or an FIA head on impact test.
The noses would have to have been higher then the drivers helmet to stop any accident like this.
