![Arrow :arrow:](./images/smilies/icon_arrow.gif)
This thread is for discussion of the race and events on the circuit.
Discussion of safe recovery of cars on track
Now, have a look at chiltons speed. 230kph, and on the next lap 243 kph!fets81 wrote:I don't know if this has been posted yet but this is from the F1 tracker app, he actually hits a top speed of 213k's coming around dunlop, thats a fair bit of pace coming around dunlop in that weather & under double waved yellows
http://giant.gfycat.com/TediousConsider ... khound.gif
I believe Alex Yoong said that braking into the first corner of Suzuka is done well after corner entry so DRS here had to be closed manually.Moose wrote:I thought DRS was meant to be auto-deactivated as soon as you lifted or pushed the brake.
at the point of the accident it's actually the same speed he reaches those speeds further down the roadgilgen wrote:Now, have a look at chiltons speed. 230kph, and on the next lap 243 kph!fets81 wrote:I don't know if this has been posted yet but this is from the F1 tracker app, he actually hits a top speed of 213k's coming around dunlop, thats a fair bit of pace coming around dunlop in that weather & under double waved yellows
Amen...Wayne DR wrote: I have also lost respect for Filipe Massa following some of his post race comments. He was out on worn intermediates, the same as everyone else, and in a car that was not setup for the conditions, so he was losing places.
If he truly was "screaming over the radio for the last five laps that the race should be stopped", he had at least two options:
1) Pit and get full wets - the appropriate tyre for the conditions OR
2) (the ballsier option) Pull into the pits, park the car up and get out - Lauda did this in '76 and it cost him the championship, BUT we still all talk about it today.
Don't make comments post race about what others should have done, when you are unprepared to act yourself!
I think your timing is off: it actually takes about 33-36 frames from the moment of impact to the point where the car is completely stationary, so little over a second. Obviously, the blunt part of the deceleration takes place in the first few frames, so accurately calculating g-forces from this video is quite impossible.emaren wrote:Wondering about the G-forces that he must have sustained led me to do a little frame counting, it appears that he went from whatever speed he was going on impact to almost stationary in around 11-12 frames. Assuming 29.97 frames/sec that gives a deceleration time between 0.27 seconds and 0.25 seconds, so assuming an average of 0.26seconds...
That doesn't matter. when video is uploaded to Youtube or other video sites, every other frame is discarded, so we end op with 29,97/30 fps. It just make the calculations we can do a bit less accurate.djos wrote:Guys most video is shot at 60 fps in Japan.
