Lotus E22 Renault
Moose
Moose
52
Re: Lotus E22 Renault
Blackout wrote:But the Merc nose will not be legal in 2015. The first version of the W05 might have a legal lengh but it is too wide...
http://www.f1technical.net/forum/viewto ... 12&t=20007
Sure, but the Merc nose is extremely close to legal (the closest of all the current noses), so Lotus will be testing something that looks very similar to the Merc nose (but presumably will be 2015 legal).
Pierce89
60
Uhhm...no. The Ferrari nose is definitely the closest to the 2015 regs. Much closer than the Merc both in length and tip height. I think I even read somewhere that the Lotus test nose would look similar to the Ferrari.
The latest version of Mercedes nose is illegal because 'too short, the first version could possibly be legalhttps://twitter.com/Graftechweb/status/ ... 9527089154
Aquanin
Aquanin
kalinka
kalinka
The latest version of Mercedes nose is illegal because 'too short, the first version could possibly be legalhttps://twitter.com/Graftechweb/status/ ... 9527089154[/quote]
That vertical line is not at FWCL :wtf:
dmjunqueira
21
IMHO looks like this new noose is a very rough prototype...2015 noose will look much more refined.
United States 2014 - Thursday (30.10.2014)
Moose
Moose
52
I would absolutely count the above as a more "Mercedes" concept than "Ferrari". The Ferrari nose is made unique by the way it tries to pull air off the top of nose, around the side, and under. This is not something the Lotus nose is trying to do at all by the looks of it.
WTF? it's just a Ferrari-like 2014 nose. It looks boxier and thicker because it's shorter than the F14 one.
It's not 2015 legal.
Crucial_Xtreme
Crucial_Xtreme
404
Blackout wrote:WTF? it's just a Ferrari-like 2014 nose. It looks boxier and thicker because it's shorter than the F14 one.
Def not 2015 legal. What's interesting is the shape on the underside of the nose.
Moose
Moose
52
If you can't see the difference the way that these noses are designed to work then you really aren't looking very hard. There's nothing here trying to keep air attached to the nose and drag it around and underneath.
I'm jutt talking about the tip/the first centimeters of the nose ; )
Hail22
144
The edge of the nose looks like a diving platform to me :roll:
Would this nose successfully create a low pressure zone underneath the edge / lip?
Gilles Villeneuve
F1T
Administrative bot
Lotus debuts 2015 nose concept
Lotus debuts 2015 nose concept - Development blog
Lotus have unveiled their new 2015 nose concept, set to be tested in FP1 by one of their drivers. The team was undecided on Thursday who would debut it.
The design is the result of development for the team's 2015 car, named E23 Hybrid, and reflects the changed regulations that will effectively outrule the team's current twin tusk nose cone. Lotus have said they don't expect their interim nose to work effectively just yet, given that is has not been designed to work with the E22, but rather aims to allow the team to run some comparisons and get real on-track data.
Technically, the nose itself, although not confirmed, looks like a shroud around the twin tusk nose, allowing the team to skip an additional crash test, one that would be mandatory if any of the front impact crash structures would have changed. As a result, the nose follows the contours of the tusks, sloping down forward towards the front wing, where two protruding elements serve as the connection points with the front wing.
Interestingly, the tip of the nose is curved up, attempting to get just that little bit of extra air underneath the nose. This immediately indicates one of the biggest challenges for most teams going into 2015, as all current noses that are set to be outruled were designed to maximise airflow underneath the nose, allowing for more downforce generated by the car's floor and its rear diffuser.
Lotus have yet to confirm if they plan to run the nose at the two other remaining events of the season.
