hope you all doing great,
i would like please to know info about the flaps which is :
1- how many degrees the flaps move ? is it 6 degrees up ?
2- what is the standard degree between the cord and the main plane ?
3- where is the servo motor that is used to make the flap changes degrees, placed ? is it in the nose ?
if you have any technical pictures that shows the mechanism would you please send it
thanks in advance
