GA was mistaken in that article, describing the turning vanes as a new development for 2015. Mercedes have been running quadruple element turning vanes for a few races now.Crucial_Xtreme wrote:GA on Mercedes supposed 2015 turning vanes used in Brazil..
http://i328.photobucket.com/albums/l349 ... 16c7d6.jpg
via AutoSport
Haha, jeez guys. I never meant to "tell' anybody how anything works. I just related how I thought something worked, based on my understanding. A misunderstanding for sure.PhillipM wrote:I would perhaps stop telling other people how things work until you've discovered that yourself then. Even most roadbikes don't use the clutch to go up through the gears.NewtonMeter wrote:I believe that driver not directly operate the clutch, apart from launch. But I'm certain that the clutch is still used during shifts - probably just automatically. I cant see how the gearbox lasts so long without having to use a clutch for shifting.PhillipM wrote:Why must they? They don't even use the clutch apart from at launch.
I looked back through the USGP pics and only saw 3 element turning vanes like below.Blaze1 wrote: GA was mistaken in that article, describing the turning vanes as a new development for 2015. Mercedes have been running quadruple element turning vanes for a few races now.
afaik .....tok-tokkie wrote:Gearbox.
When changing gear is the clutch used or is the ignition cut? The changes are incredibly quick so I thought the boxes were like those on the twin clutch Honda VFR 1200 bike. The informed opinion here is that the F1 gearbox is nothing like that. Ignition cut works fine for upchanges but what about down shifts?
I think of AutoGyro's gearbox and it seems to me that it really would be an excellent unit to use in F1.
In reference to my previous two posts, I knew I read somewhere that the clutch is electronically controlled.PhillipM wrote:I would perhaps stop telling other people how things work until you've discovered that yourself then. Even most roadbikes don't use the clutch to go up through the gears.NewtonMeter wrote:I believe that driver not directly operate the clutch, apart from launch. But I'm certain that the clutch is still used during shifts - probably just automatically. I cant see how the gearbox lasts so long without having to use a clutch for shifting.PhillipM wrote:Why must they? They don't even use the clutch apart from at launch.
Also...The on-board computer automatically cuts the engine, depresses the clutch and switches ratios in the blink of an eye
But these articles are pretty old. I assumed they still work more or less the same, so my bad. Infact, Ross Brawn explaines a bit how a modern seamless shift works here (only part of the video):Gear selection is initiated by the driver through paddles on the steering wheel (McLaren had an early version with buttons), the electronics decide the timing of the selector drum and clutch actuation, along with ignition cutting for upshifts and throttle blipping for downshifts
Very interesting, I did not know that about the gearboxes. Thank you!Jolle wrote:I read an article in a motorcycle magazine about the honda motogp gearbox, which is also seamless nowadays. The shifting is done with special rockers and springs inside the shaft that holds the gears, a bit like a freewheel on a pushbike. when the next gear is selected, it's "locked" and the last gear goes into freewheel. This gives a bit of a "bang" (because there is a few mm give for when it catches the next rocker) but that would mean only one or two fires of the engine. I also think the drivers can select different shifting times to nurture the gearbox. For instance, if FP1,2,3 they have only power after a shift is locked, also in the race when they are on coast, in Q or when they push in a race they can go truly seamless and gain time plus stressing the gearbox.
https://cdn.rideapart.com/wp-content/up ... ockers.jpg
So that means that a driver has a large influence how long a gearbox lasts and that gearbox failures sometimes is drivers pushing too hard (in the wrong settings)SiLo wrote:Very interesting, I did not know that about the gearboxes. Thank you!Jolle wrote:I read an article in a motorcycle magazine about the honda motogp gearbox, which is also seamless nowadays. The shifting is done with special rockers and springs inside the shaft that holds the gears, a bit like a freewheel on a pushbike. when the next gear is selected, it's "locked" and the last gear goes into freewheel. This gives a bit of a "bang" (because there is a few mm give for when it catches the next rocker) but that would mean only one or two fires of the engine. I also think the drivers can select different shifting times to nurture the gearbox. For instance, if FP1,2,3 they have only power after a shift is locked, also in the race when they are on coast, in Q or when they push in a race they can go truly seamless and gain time plus stressing the gearbox.
Looking back through previous photos, the quadruple element turning vanes first appeared at the Belgian GP. I can only surmise that their introduction coincided with the final nose development, to take advantage of the improved airflow around that region.Crucial_Xtreme wrote:I looked back through the USGP pics and only saw 3 element turning vanes like below.Blaze1 wrote: GA was mistaken in that article, describing the turning vanes as a new development for 2015. Mercedes have been running quadruple element turning vanes for a few races now.
http://i.imgur.com/CO7jLON.jpg
Scarbs said the same thing regarding new 4 element turning vanes being tested in Brazil. -> Brazil Tech-AutoSport
Edit: but I see Scarbs posted pics of 4 element turning vanes back in Austin. Apologies.
plain wrong on the Merc injector pressure - read upPlatinumZealot wrote:Never said that you don't get more horsepower. I said it won't give that much because (1), mercedes always had a 500 bar system. Even the BOSCH system on street cars have 500 bar. It was only unfounded rumours that they had a 300 bar system.Ferraripilot wrote:To the poster who stated injection pressure does not result on more power.
A higher pressure direct injection system allows the same amount of fuel to be sprayed at a finer and more controlled mist resulting in more molecules being exposed to the flame front which results in quicker ignition of all molecules which yields more torque. Higher injection pressure is indeed directly related to torque and efficiency because of the above. If the Mercedes engine were operating at a 200-300bar system which is what was conjectured they ran, then going to 500bar or thereabouts would indeed increase efficiency.
higher Injection pressure also allows you to pulse the injector faster with a more consistent fuel delivery.It is really for efficiency. Mercedes always had the higher pressure system anyways.
It was indeed Spa where they were first run..Blaze1 wrote:Crucial_Xtreme wrote:Blaze1 wrote: Looking back through previous photos, the quadruple element turning vanes first appeared at the Belgian GP. I can only surmise that their introduction coincided with the final nose development, to take advantage of the improved airflow around that region.
http://img3.auto-motor-und-sport.de/Mer ... 803441.jpg
http://www.f1technical.net/forum/viewto ... start=2400
Cheers Matt.Matt Somers wrote:It was indeed Spa where they were first run..
http://somersf1.blogspot.co.uk/2014/08/ ... s-wo5.html
