Lotus E22 Renault
Shafto
Shafto
Re: Lotus E22 Renault
Don't look too bad to me. Looks kinda good.
Crucial_Xtreme
Crucial_Xtreme
404
I saw Scarbs mention the camera on an AutoSport Plus article. In Brazil Lotus used a camera that was measuring front tyre contact patch & deflection.
via AutoSport
seems to me like a hint that lotus, as they have been or intended before, to put effort in having a car that is light on the tires / having as little wear on it as possible.
matt21
86
I´ve read somewhere, that Lotus has some "interesting solution" to transfer power from the engine to the rear wheels.
Does anybody know something more detailed about that rumour?
Abu Dhabi 2014 - Thursday (20.11.2014)
https://twitter.com/Albrodpul/status/535478220389646336 Image
mikeerfol
68
So are they running the 2015 nose again tomorrow?
emmepi27
emmepi27
141
Exhaust's heat protection (Amus)
And with the season finished, I hope that they will burn down both cars so they don't have to go back home with them.
ericsonnek
ericsonnek
Lotus during the post season tests in Abu Dhabi with a new Mercedes engine? :)
can't imagine how they're going to just 'stuff' a Merc engine in a car that was designed for a Renault PU. Its not that it's impossible, but regarding the short time and the kind of team i'm doubtfull whether that'll actually happen.
But, you never know.
trinidefender
trinidefender
317
Manoah2u wrote:can't imagine how they're going to just 'stuff' a Merc engine in a car that was designed for a Renault PU. Its not that it's impossible, but regarding the short time and the kind of team i'm doubtfull whether that'll actually happen.
McLaren did it with the Honda engine
Moose
Moose
52
Given that the Merc is more compact than the renault in pretty much every way, I doubt it'll be a major issue. If they were trying to go the other way, they'd need to manufacture new side pods etc, but this way they should be able to bodge it.
It's impossible to bolt the Merc PU on the Lotus chassis, even if the mounting points are the same for everybody. Lotus needs to build a new monocoque to do that because the Merc compressor hangs in front of the engine and the Merc oil tank is very different etc... Lotus needs to dig a 'niche' in the monocoque that can host the Compressor, its airbox, the different oil tank etc... that would cost them muuuch money and muuch time. It's like making a new chassis.
Mounting a Renault PU on a Merc monocoque requires making a different Gear box too... a Gbox that can house the turbine AND the compressor...
mikeerfol
68
I'm sure if they were going to do it they would already announce it.
They'll just have to stick to the dodgy Renault PU for a couple more days until the suffering is over :) There's no way they will going to use a Mercedes PU because, as Blackout wrote, even though the mounting points are the same for everyone you have to have a special chassis prepared to take another engine.
