Spiros-Foivos wrote:Hello , This is my first post in the forum so far , i am 17 years old and currently studying to get to the mechanical engineering university where i live at Greece . I have some questions regarding tyre grip and slip angle . As far as i understand grip the same tyre is determined by a number of factors , the main ones are the weight on the tyre and slip angle while cornering. I have read that weight shifting helps a the tyre (that the weight is shifted to ) to produce more grip and the slip angle gets bigger resulting in more grip .
But i dont understand why they say that when a car is nose heavy it tends to understeer on cornering . As far as i understand a nose heavy car while have more weight on the front tires thus producing more grip ? I thought about polar moment of inertia but still i can't quite understand why this happens ...
Also when cornering why it is sayed that the center of gravity should be closer on the wheels of the drive axle ? Wouldn't this cause in a rwd car the front tires to raise and reduce available grip for turning ?
And to clear things up what are the all the factors that determine tyre grip in the same track-car
and does more slip angle mean generally more grip ?
Thanks in advance ! I have these thoughts eating me and can't study maths and physics for school
Hi, welcome.
IMO slip angle is more of an effect.
Tire grip depends on rubber compound, temperature, camber, inflation pressure, rim width, tire construction, road surface, etc.
Google weight transfer.
The more vertical load a tire has the more grip it has, true but
the less efficient it gets, so if you double the vertical load you get a bit less than 2x the grip. Thus a net loss.
In an ideal world the center of gravity CoG should be in the wheelbase center.
In performance or race cars the front tires are usually narrower and smaller than the rear ones to ease turn in and for aerodynamics reasons. So being the rear tires fatter and bigger this allows for more grip thus allowing the CoG to be moved a BIT to the rear and just a bit.
A higher slip angle doesn't necessarily mean more grip.
As you can see here
The red line is a race tire and the blue one is a street tire.
In fact most (if not all) high performance tires produce their maximum cornering force at lower slip angles than street tires.
Of course the maximum cornering forces are higher in high-performance/race tires.
As for math, you'll only need formulas for weight transfer.
To determine tire grip you need to look at tables/charts for an specific vertical load.
AFAIK no math formula can accurately predict the real world performance of a tire, at least not a highly developed race tire.
