How do you calculate the temperature of the air inside the tire? I have the initial pressure and temperature of the tire and the pressure after the run. Using the ideal gas equations gives me some ridiculous results. What are the equations for say nitrogen?
For example I start with 210kPa and 25°C and after the run the pressure is 290kPa. Ideal gas equations give me (25°+273°)*290kpa/210kpa=139°+273°
I think 139°C is too much because the peak rubber temperature is 120° and the average is 98°. I would expect air temperature close to the average rubber temp as it is the source of the heat.
