(KVRC) CSR 2014
cdsavage
cdsavage
19
(KVRC) CSR 2014
Thread for my 2013 entry is here: http://www.f1technical.net/forum/viewto ... 14&t=14949
I'm entering KVRC for 2014 with a brand new car, making some changes to my modelling and testing methods but otherwise hoping to pick up where I left off last year.
The images here are of a finished model but before I had done any CFD testing, so my entry for the first round looks a bit different.
astracrazy
astracrazy
31
Re: (KVRC) CSR 2014
Nice one.
thanks for sending me the renders btw, we will be putting them on the website after the first race
CAEdevice
49
Re: (KVRC) CSR 2014
I've so much to learn from this car... very good job!
CAEdevice
49
Re: (KVRC) CSR 2014
So curious about the max front wing downforce with Monaco setup ;) It is my worse weak point ...
machin
162
Re: (KVRC) CSR 2014
This is a very nice looking car!
Interesting to compare your 2013 Silverstone car aerodynamic coefficients compared to your 2014 Monaco results:-
2013 Silverstone, CdA = 1.2461, ClA = 2.6262
2014 Monaco, CdA = 1.2457, ClA = 2.5697
i.e. Very little difference between the two, despite the fact that the rear wing now has lost the lower element and the front wing is narrower.
Good work!
CAEdevice
49
Re: (KVRC) CSR 2014
It's also interesting to notice that CdA values are quite similar even if Silverstone seems to be a lower DF track than Monaco.
machin
162
Re: (KVRC) CSR 2014
That will partly be down to the fact that the wings are now smaller... but I'm impressed that cdsavage has managed to maintain the same L:D ratio even though he has less wing area to play with.....
RicME85
52
Re: (KVRC) CSR 2014
clearly an f1 team design guru ;)
cdsavage
cdsavage
19
Re: (KVRC) CSR 2014
Thanks for the comments. So far most of the gains over last year are through avoiding the problems that the old car had, rather than anything tricky. I was pretty happy with the overall downforce and drag figures for round 1 but there was a problem with my testing that lead me to believe I had more rear downforce than the final KVRC simulation gave me, and so I ended up with more front downforce (and drag) than I needed. Hopefully for round 2 I'll be closer on the center of pressure.
RicME85 wrote:clearly an f1 team design guru ;)
Thanks, but I can assure you I'm not :D
cdsavage
cdsavage
19
Re: (KVRC) CSR 2014
Aliraza153 wrote:I'm not sure you can fit an engine in that car...BUT that's the whole point of this competition I think! The slimmest the regulations will allow. Good job!
We were given templates for the engine and gearbox/rear crash structure, as well as some cross-section area requirements at 2 places along the sidepod. I don't think the overall shape is too different to the 2014 f1 cars.
This image doesn't show the cooling outlets, which I added on either side of the gearbox, making the car a little bulkier.
I neglected updating this thread when the competition started - I'll post some images from each round when i get time. In the mean time, the 2015 competition is getting underway, you can sign up here: http://www.khamsinvirtualracecarchallen ... lenge-2015
