As opposed to the 4T's 3 non-power strokes?
L.O.L...
Seriously though W-F1, if you want a 1T mill, look up the Maxim gun, its yet another 19th century invention..
the usual 2 stroke early opening of the exhaust port is not a problem eg in the present electrically turbocompounded F1uniflow wrote:They run out of blow down time, time for the gas pressure to drop below the trasnsfer pressure. At this point transfer gasses get pushed back down into the crank case for a time before transfer can occur. ........WilliamsF1 wrote:Why does the power fall drastically in a 2 stroke? Is it because the expanding gases leave through the exhaust port
Or any hybridTommy Cookers wrote: this is the Crecy argument, but it makes more sense in F1
Not sure what you are trying to work out there.WilliamsF1 wrote:I assumed a case werewuzak wrote:No, the $T's piston speed will be double (assuming teh same crank throw).WilliamsF1 wrote:So if the 4 stroke is at 10000 rpm and 2 stoke is at 5000 rpm both will have same piston speed and same power and efficiency?
The 2T will have slightly less air throughput. Power and efficiency depend on a lot of things, but I wouldn't expect them to be wildly different.
4t = B x S
2t = B x 2S
Except that you never get back as much energy from the scavenge air as was taken to compress it in the first place.Tommy Cookers wrote:the usual 2 stroke early opening of the exhaust port is not a problem eg in the present electrically turbocompounded F1uniflow wrote:They run out of blow down time, time for the gas pressure to drop below the trasnsfer pressure. At this point transfer gasses get pushed back down into the crank case for a time before transfer can occur. ........WilliamsF1 wrote:Why does the power fall drastically in a 2 stroke? Is it because the expanding gases leave through the exhaust port
because this wasted energy is recovered by the turbine
(I had found it unprofitable to say that the energy used in pumping extra air is not fully 'recoverable' ie compensatable somehow, and likewise to say that the benefits of raised exhaust pressure are in principle rather independent of the use of extra air)wuzak wrote:Except that you never get back as much energy from the scavenge air as was taken to compress it in the first place.Tommy Cookers wrote: the usual 2 stroke early opening of the exhaust port is not a problem eg in the present electrically turbocompounded F1
Also, in the time of the Crecy the excess air was great for turbo-compound solutions, as it lowered the exhaust gas temperature to a level which could easily be handled by the turbine materials of the time.
In contrast, the Allison turbo-compound's exhaust gas temperature was above what the best turbine blade materials could handle (IIRC it was about twice the Crecy's).
Lower temperature means that less energy can be extracted from the turbine.
And use more fuel doing so....J.A.W. wrote:-an N/aspirated 2T should/would readily beat an N/A 4T mill of equal cc..
wuzak wrote:And use more fuel doing so....J.A.W. wrote:-an N/aspirated 2T should/would readily beat an N/A 4T mill of equal cc..
Seriously JAW, 2 strokes and 4 strokes are not directly comparable by their nominal capacity.
The 2 stroke makes more power than the same nominal capacity 4 stroke because it moves more air and uses more fuel. Simple, really.
